Old 02-16-2015, 10:06 AM
vstol vstol is offline
Default What type of flare for Corvette brakes
I am plumbing my project for C4/5 corvette brakes and was using the standard fittings and double flare. I was talking to a builder and he said you need to use a metric bubble flare to attach your line to the caliber. Is there an adapter or someone who make a hose that can go from standard to metric to fit the caliber? Thanks Kevin
Old 02-16-2015, 11:03 AM
Schwartz Perf Schwartz Perf is offline
Supporting Vendor
Those calipers take a metric banjo fitting not a bubble.. Unless you're using the factory brake hoses perhaps. But for the trouble, you can just get a banjo fitting with an AN fitting on it.
For adapters, Edelmann has a lot to choose from: http://www.plews-edelmann.com/hydraulic-brake-fittings/
-Dale
SchwartzPerformance
Where classic style meets modern technology.
SchwartzPerformance.com
GMachineChassis.com
LSxEngines.com
Facebook | Instagram | YouTube
Old 02-16-2015, 11:52 AM
Vince@Meanstreets's Avatar
I have used the standard 69 Camaro hose with the 3/8" banjo along with the 10mm banjo bolt and 10 mm copper washers with no problems. That way you can use a standard Inverted flare
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 02-16-2015, 02:06 PM
Great thanks
