Old 02-16-2015, 02:45 PM
69lsvert 69lsvert is offline
Default C6 Z51 brakes on 69 camaro
Guys need your help. Who makes the adapters, brackets, hubs and parts to install Z51 calipers and rotors front and rear to a 69 camaro? What I have on the car now are CPP 2 inch drop spindles part# 30100 and a 12 bolt with a four link. Any help would be appreciated.
Old 02-16-2015, 03:16 PM
Vince@Meanstreets's Avatar
Give Tobin a call. He has everything you will need.
http://www.kore3.com/
Tell him that Lateral-g got you there.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 02-16-2015, 03:44 PM
Thanks I'll do that. I've heard a lot about kore3
Old 02-17-2015, 08:29 AM
hifi875's Avatar
hifi875 hifi875 is offline
thats what i have on the front. got all parts from tobin^^.
69 camaro
03 z06
90 mustang coupe
1950 international l110
1993 mustang gt
Old 02-17-2015, 04:39 PM
Talked to Tobin today and he hooked me up. All I had was front and rear calipers and rotors so I pretty much needed all the other stuff including parking brake. If anyone needs brake stuff like I did call Tobin at Kore3.
Old 02-19-2015, 01:54 PM
I see there's been quite a bit of views on this thread so there's either some bored people or some interest on this install. I'm waiting on some things to come in and my subframe is sitting with motor and trans in it and rear end is getting painted while my car is on rotisserie. When the stuff comes in I'll take some good pictures just in case anyone's interested.
Car is a convertible disc brake car with 12 bolt rear stock subframe with cpp 30100 2 inch drop spindles just to let you know what I'm starting with.
Old 02-20-2015, 03:24 AM
Sheck44's Avatar
Sheck44 Sheck44 is offline
Default Kore3
I had the almost identical setup and it worked great !! Tobin is awesome .. love to see some pics for sure
You going manual or with a booster
Cheers
Steve
'Build it RIGHT the 2nd time'
69' SS X11 PRO-TOURING - SOLD
73' FJ40 LS - SOLD
1966 FJ40 R2.8 -SOLD
911 Hotrod - SOLD
2002 Gated 360
Next up - "Killer Piggy"
67' Camaro - Take-Over'
Old 02-21-2015, 10:07 AM
Cheers
Steve
Need some advice on that. Car came with booster I think an 11" from factory and I had thought about going manual but am leaning towards power. Tobin is sending me some instructions on measuring for master cylinder. Also what company is good for getting pre bent hard lines from?
Old 02-21-2015, 12:35 PM
Sheck44's Avatar
Default Booster
I ran an 8" dual booster and it worked great ... I'd definitely go with what Tobin recommends though. He's definitely the man when it comes to setups like this.
If at all possible, you should try to do your own lines, it's actually very easy if you have a proper flaring tool, and a couple of benders. I actually find it fun (but sometimes painful) to do my own lines and if you use Ni-cop lines they are very easy to work with ....
Cheers, good luck
Steve
73' FJ40 LS - SOLD
911 Hotrod - SOLD
2002 Gated 360
