Old 02-17-2015, 05:44 PM
MattO MattO is offline
Default E85 or meth?
I'm gathering as much information as I can right now and wanted to reach out to the Lat-G community and get their input;
I'm looking at increasing the output of my engine by cranking the boost on my turbo to around 18psi. The issue I have with this is not tuning so much as heat. The cylinder liners in my engine are REALLY thin and I'm worried that putting too much heat into them might cause a failure of epic proportions.
I know E85 would solve every issue here, but it's not exactly widely available, so I was wondering what you guys thought about injecting a healthy portion of methanol and water into the intake to keep cylinder temperatures down. I want to know which is the better route to go to keep the temps in check.
"I should have just started smoking crack. Its just as addicting and WAY cheaper..." --unknown
Old 02-17-2015, 06:15 PM
Flash68's Avatar
Flash68 Flash68 is offline
I am going to run E85 and I have 3 stations that are all within 10-20 minutes of me triangulating my home base. That was enough for me to go for it.
Looks like you many more stations up in your hood. I'd go for it.
http://www.e85prices.com/california.html
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 02-18-2015, 08:44 AM
Oh, I have a plethora of stations around me, but I'm more concerned with when I travel.
Old 02-18-2015, 10:13 AM
NOPANTS68 NOPANTS68 is offline
Are you injected or carb'd?
1929 Roadster Pickup
1961 Chevy Parkwood Wagon
1956 Chevy 210
Smithcraft Collision and Restoration
Newcastle , CA
Old 02-21-2015, 11:02 AM
Injected
Old 02-21-2015, 03:30 PM
novahollic's Avatar
novahollic novahollic is offline
I'm assuming LS engine? What ECU are you running? If you can make it a true flex fuel car, like you can with the newer factory ECU's, then you don't have to worry about having e85 available all the time.
Old 02-21-2015, 03:54 PM
Flash68's Avatar
Yep, Stielow posted about making XV (and maybe the update to Jackass?) E85 compatible.
2014 4 tap Keezer
Old 02-21-2015, 05:43 PM
Nope, no LS for me. I'm not that smart. No, instead I built an Atlas 3.5L inline 5cyl engine that came in my GMC Canyon. It rocks a P12 ECM which is only just a hair better than a Texas Instruments calculator. So yea, I'm kind of an idiot...
Old 02-22-2015, 06:30 PM
novahollic's Avatar
Not an idiot. Just working with what you've got. Does the P12 ECU not have Flex Fuel capability? I think most 05-newer car do. If you post up an HP Tuners file for the truck I can check.
The problem with running a strictly e85 tune is that you don't always get 85% ethanol in your fuel. If you end up with 70% ethanol, you be running too rich all the time. If you install an ethanol gauge you can monitor it, just so you know where you're at.
Or you can run e85 "race gas", but that defeats the "poor man's race gas" idea behind it.
Old 02-22-2015, 07:13 PM
Flash68's Avatar
Nice.
Since you, MattO and I are in Norcal, we should not have a problem with the summer/winter blend deal E85 users face in other parts of the country. My research before choosing to go E85 on mine showed Norcal pump E85 has been very stable in the 85-90% range year round, at least that was the case when I dug into in this a year or so ago. I have the Quickfuel test tube and will be checking each batch of fuel.
FWIW, some pump E85 I bought in Concord in late 2013 registered 88%... I had some leftover after the dyno and I decided to test it a month or so ago and it registered 84%.
2014 4 tap Keezer
