Old 02-24-2015, 05:18 AM
Errnie-ZL1 Errnie-ZL1 is offline
Default 1968 firebird pro touring project LS1
Item Location (City/State)eterborough Ontario Canada
Price:$17,500.00 O.B.O
Description:1968 firebird pro touring project LS1
Hey guys up for sale as i have to many projects on the go
1968 coupe
Calgary AB car
Imported to ON 25 years ago approx
Rewired the whole car with an American Autowire kit
Rear end is 3.73 posi
Disk brake conversion up front (new lines etc)
Power brakes, power steering
Steering is a quick steering, converted to rack and pinion (kit made by unisteer)
Grant wooden steering wheel
LQ9 engine (120k from 2003 eslcalade, 6.0L) I kept it fuel injected
LS1 intake manifold
LS1 throttle body (cable)
LS1 FAST fuel rails
LS1 fuel injectors
Wildwood clutch master kit
Tremec tko600 (bought brand spanking new)
Lokar shifter and knob
Aluminum rad (not sure of brand, was already on car)
Electric fans (dual)
Current performance engine wiring kit
Holley engine accessory kit (brackets, alternator, power steering, pulleys etc)
Holley oil pan for first gen fbody swap
Holley ls valve covers (black)
Frame connectors (came with car, not sure of brand etc)
Tanks Inc steel fuel tank for FI cars
6AN PTFE fuel lines
AEM 3000 fuel pump
Car comes with all new in box black interior
Carpet, door panels,headliner, seat foam seat covers everything will be new in box you just have to install
The following parts are all from American power train and are brand new
Clutch
Flywheel
Driveshaft
Bell housing
Trans mount and crossmember
I know I'm forgetting some things here and there. The car doesn't have a heater or fan, I had to remove the original one as it was interfering with the engine when the engine would rock slightly side to side during load on and load off. The plan was to go with a vintage air system which sits under the dash fully inside the car and has a dual purpose (heat and ac). Horn doesn't work as I did not get a chance to rewire the steering column yet but have the wiring kit for that too. All lights work otherwise. Needs interior work as its all original; roof trim is missing on inside as I had to tear it out when rewiring the car. I have all new interior in black from classindustries
door panels carpet seat foam and covers head liner etc.
Consider this car in place of a Camaro; both are f-body cars
Old 02-24-2015, 05:22 AM
Default more pics
a few more pics
Old 02-24-2015, 05:24 AM
Default 3rd set f pics
3rd set of pics
Old 02-27-2015, 05:01 AM
tigerhays's Avatar
tigerhays tigerhays is offline
Default Car
if it was in Texas it would sell today!
Old 02-28-2015, 03:04 AM
Sheck44's Avatar
Sheck44 Sheck44 is offline
Default Shipping
Texas ... About $1500 to get it there
'Build it RIGHT the 2nd time'
69' SS X11 PRO-TOURING - SOLD
73' FJ40 LS - SOLD
1966 FJ40 R2.8 -SOLD
911 Hotrod - SOLD
2002 Gated 360
Next up - "Killer Piggy"
67' Camaro - Take-Over'
