Old 02-24-2015, 06:21 PM
DBasher's Avatar
DBasher DBasher is offline
Default SBF help
The donor motor for my wife's mustang is out of a 1985 Lincoln TC. I've already got the serpentine set up figured out as well as the water pump rotation...Ford sure liked to change things for whatever reason.
The timing chain cover has a boss for the mechanical fuel pump but it's blocked off internally. I've found a tc cover that will work and thought I was in the clear...but what's going to drive the fuel pump? Can I purchase the eccentric dealio and will it bolt onto this cam? What are my options besides an electric fuel pump?
Edit; I figured it out.
