Old 02-26-2015, 08:03 AM
69hugger's Avatar
69hugger 69hugger is offline
Default Fuel pressure sensor?
I want to add a fuel pressure sensor to my FAST XFI 1.34 system. FAST offers a sensor kit that has the sensor, wire harness, and billet "Y" fitting, but I really only need the sensor itself as I plan to just tap it into a fuel rail, & I can make my own harness.
I hate to pay $100 for the kit if the sensor alone costs a fraction of that.
Does anyone know of a 0-100 psi 3 wire oem type sensor? Where can I source such a sensor?
Thanks for any advise.
Bill
Bill
'69 Camaro / 534 BBC / DSE Built
'67 C10 / LS-3 w/Magnuson / Roadster Shop Chassis (SOLD)
'71 Blazer / LT4 / 8L90 / Roadster Shop Chassis / Ride Tech Air Susp.
Old 02-26-2015, 08:55 AM
Schwartz Perf Schwartz Perf is offline
Supporting Vendor
http://www.summitracing.com/parts/da...FQyUaQod9GoA1A
Maybe?
-Dale
SchwartzPerformance
Where classic style meets modern technology.
SchwartzPerformance.com
GMachineChassis.com
LSxEngines.com
Facebook | Instagram | YouTube
Old 02-26-2015, 04:03 PM
Vince@Meanstreets's Avatar
I guess you just found that $100 dollar question. Not only are you getting a part but your are taking out the guess work with that $100.
If you look at the FAST site the sensors are $175. WTH??
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 02-27-2015, 05:54 AM
69hugger's Avatar
For a price difference of $24, I'd just buy the FAST setup. I thought I could probably get the sensor for a fraction of the cost of the kit.
Thanks for the input.
Bill
Bill
Old 02-27-2015, 06:15 AM
MeanMike MeanMike is offline
The fast sensor is 12v in 0-5v out 100psi sensor. The xfi looks for any 0-5v input. There are sensors on eBay that are much cheaper. You can find a 5v, 12v, 100psi or 200psi sensor and it will work fine as long as it is a 5v output. The fast sensors are SSI brand. You can scale the pressure range in the software, so any pressure sensor will work fine.
Old 02-27-2015, 08:24 AM
69hugger's Avatar
Thanks Mike. That's precisely the info I was looking for!
Bill
Bill
