Old 02-27-2015, 01:26 PM
Default 4l80 in first gen
Does anyone have some pictures of a 4l80 in a first gen and how much room is there for the cooling lines? My trans is a 97 and newer with one port in front and one near the rear of the trans. Has any one ever used the banjo fittings they have for the trans cooling lines ? I would only use them if it was tight.
Not sure how I feel about them
http://www.ebay.com/itm/6AN-4L80E-GM...-/231278300872
Thanks!
Old 02-27-2015, 02:50 PM
Schwartz Perf Schwartz Perf is offline
Supporting Vendor
Sorry, I don't have any pics of the 69 we did with a 4L80 of that area. But I think the front port was tight, and the rear one was not.
We've used the banjo fittings quite often. If you can get away with using the stock rear fitting you can use one of these: http://www.purechoicemotorsports.com...rod/prd338.htm
Here's banjo's individually too:
http://www.purechoicemotorsports.com...rod/prd408.htm
-Dale
SchwartzPerformance
Where classic style meets modern technology.
SchwartzPerformance.com
GMachineChassis.com
LSxEngines.com
Facebook | Instagram | YouTube
Old 02-27-2015, 08:29 PM
69x22's Avatar
69x22 69x22 is offline
I was wandering myself if a stock floor board would clear the 4L80?
1952 Ford F1 817 HP 8-71 Supercharged 502
1957 Chevy 454LSX
1969 Camaro 830 RWHP ProCharged LS 416
https://lateral-g.net/forums/show...ighlight=yenko
https://lateral-g.net/forums/showthread.php4?t=34171
Old 02-28-2015, 03:43 AM
Bad Bowtie Bad Bowtie is offline
X2 This is on my list for my wife's Camaro I'm getting started on soon.
BB
