Old 03-07-2015, 02:15 PM
dinos67's's Avatar
dinos67's dinos67's is offline
Default PCV and catch can questions
So I had some questions about a PCV system I have an LS two and the issue that I'm having is my aftermarket valve covers do you not have a PCV or vent option on them so I'm trying to determine what it is that I need to do to get one.do I have a bung welded on my valve cover and then route that to the valley cover? My next issue that I have is about a Catch can Based upon what it is that I've been reading I certainly want to get one I'm just not sure how to plummet either any help would be greatly appreciated.
I found the shop that makes these custom Catch cans
http://www.rndfabrication.com/AdditionalProducts.html
If you need me to send any pictures or anything that would possibly help please let me know so I can send something out
Old 03-07-2015, 04:07 PM
dhutton dhutton is offline
Some good info here:
http://www.shophemi.com/images/media..._ccv_bible.pdf
Don
Old 03-07-2015, 08:00 PM
dinos67's's Avatar
Default Follow up
Don thanks for getting back to me this article on however does it address my issue again I do not have a PCV provisioning on my on my valve cover and I'm trying to determine whether or not I need to weld a bung on the valve cover or if the CAT scan will work as a PCV vent and store the nasty oil.
Old 03-07-2015, 08:17 PM
Tuske427's Avatar
Tuske427 Tuske427 is offline
Have you read this thread yet? They show numerous routings and discuss the need for a proper set up:
http://ls1tech.com/forums/generation...outing-ok.html
Long Live the Muscle Car
https://lateral-g.net/forums/showthread.php4?t=26338
Instagram: @tuske427
Old 03-07-2015, 08:18 PM
scherp69's Avatar
scherp69 scherp69 is offline
I bought the catch can from Mike Norris and according to his site, it doesn't need to hook up to the valve cover. I hooked mine up the same as on the site. http://www.mikenorrismotorsports.com...atch_Cans.html
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
Old 03-07-2015, 08:33 PM
G-Body's Avatar
G-Body G-Body is offline
Catch can mounted behind my fender well hidden.
