Old 03-09-2015, 08:57 AM
Blake Foster's Avatar
Default Speedtech Performance NEW First / Second gen SubFrame
SPEEDTECH PERFORMANCE
Monday, March 15, 2015
You may already know Speedtech Performance has acquired the rights and production of the Ironworks CAD designed full chassis for 67-72 C10 Trucks, 55-57 Chevys & 68-72 Chevelles/GM A-Bodies. What you may not know is we also currently have NEW Front Subframe & Suspension packages in the works for 67-69 F-Bodies, 68-74 X-Bodies & 70-81 F-Bodies.
Here is the juicy part. Speedtech Performance contracted Ron Sutton to optimize the front suspension & steering geometry, the way only he can, on all the new Speedtech Performance chassis and front subframes. For the first time, you can bolt in a chassis or front subframe with Ron Sutton Race Technology optimized geometry.
Ron said, “This was a tough project, because we needed to achieve the optimum front dynamic roll center for any suspension strategy the customer wants to run ... and we did it ... it turned out perfect. This combined with the best Ackerman of any available front end, optimum camber gain and minimal jacking effect ... makes these the best handling, steering & driving chassis and subframes available. They are an upgrade from Speedtech’s current product offerings and frankly any full chassis or front subframe in the Pro Touring market today.”
The front suspension is based around the NEXT Generation of the ATS Forged 7075 Aluminum Spindle design that now makes it possible to have what Ron calls, “The best possible multi use suspension package available.” Ron stated the Next-Gen ATS spindle in its new configuration offers “Better geometry than any Corvette or Corvette copy spindle.”
Some of the many technical advantages of the new ATS Spindle & Speedtech Chassis/Subframe Geometry:
• Reduced KPI/SAI angle
• Requires less caster to achieve optimum full tire contact patch
• Significantly less scrub radius for improved grip in tight turns
• HD C7 hubs & bearings standard
• Improved design steering arm with max Ackerman
• Optimum rack & pinion location
• Amazing 95% Ackerman achieves optimum tire slip angle, significantly increasing front tire grip
• Virtually Zero Bump Steer (.005”)
• Up to 30 degree turn angle (tire size dependant)
• Roll center achieves optimum dynamic location for low, mid & high travel suspension strategies
• Increased shock length allowing higher suspension travel
• Excellent .76 motion ratio for improved shock response & control
• 3-Piece splined Speedway Engineering sway bar standard – Wide range of rates available
• Excellent for Autocross, Road Course and Street Driving
The other exciting part is that we have arranged for Ron Sutton to provide our competitive clients custom Autocross/Track Day suspension combinations & tuning support on an individualized basis (for a small flat fee) for the full line of full chassis & front subframes. Ron Sutton Race Technology is an authorized dealer for the entire Speedtech product line.
We are REALLY excited about this game changing chassis and front subframe/suspension line and although it is a couple months from being ready to ship we just felt we should let you know. We are taking pre-orders through Speedtech Performance and Ron Sutton Race Technology starting March 15th. Once the chassis & subframes are in production, they will be available through all Speedtech dealers. Stay tuned for pricing and other options.
Contact Speedtech Performance at:
Phone: (435) 628-4300
Shop: 3884 S. River Road, Bldg. A, St. George, Utah 84790
Email: [email protected]
Website: SpeedtechPerformance.com
Contact Ron Sutton Race Technology at:
Phone: (916) 834-8051
Website: RonSuttonRaceTechnology.com
Blake Foster
www.speedtechperformance.com
Old 03-09-2015, 09:26 AM
Sieg's Avatar
Sieg Sieg is offline
Well played Blake.
Old 03-09-2015, 10:32 AM
Jr's Avatar
Jr Jr is offline
Will this new sub on the first gen camaro use your current upper and lower control arms? Will the new sub allow for a wider front tire...say 315?
Old 03-09-2015, 10:47 AM
ALL NEW, ZERO cross over parts except the brakes if you currently have ATS spindles. this was a blank sheet of paper. 315 YES (mods to the inner fender will be required)
Blake Foster
Old 03-09-2015, 10:59 AM
nicks67ca nicks67ca is offline
Nice. Can't wait to see pricing and more details......
To Soon?
Old 03-09-2015, 11:48 AM
To Soon?
YEA TOO SOON!!!
Blake Foster
Old 03-09-2015, 01:01 PM
Build-It-Break-it's Avatar
Originally Posted by Blake Foster View Post
YEA TOO SOON!!!
How long until a release date Blake? Or at least pictures !?
Ahmad B
Old 03-09-2015, 01:29 PM
Jr's Avatar
Jr Jr is offline
What about shocks? Will there be offerings from ridetech and jri?
Old 03-09-2015, 01:36 PM
standard will be Viking Doubles. RideTech Tripples will be an option and JRI is a possibility have to discuss with them this week.
the JRI's will be custom Valved based on our requirements if we can strike a deal with them.
Blake Foster
Old 03-09-2015, 01:41 PM
working towards mid April. a lot right now is dependant on how fast the Forging company can make the required changes to the dies and then produce a run of spindles.
the rest is a week or 2 from being ready to laser cut.
Blake Foster
