Old 03-15-2015, 07:42 PM
dcrider69 dcrider69 is offline
Default $1,000,000 question!
I have read and spoke with a few different people. I am looking for a straight up, majority rules answer.
T-56, magnum, lgt-700, etc...
Which one/manufacturer fits into a stock 69 Camaro, factory 4 speed car with console, WITHOUT doing any tunnel modifications or witchcraft necessary?
Just looking for a bolt in and go product. I prefer to do mechanical clutch, unless someone can change my mind. Thanks in advance! I would love to hear answers from people who have already done this.
Old 03-15-2015, 09:36 PM
If the car is lowered, the tunnel needs sliced for a t56 to do it right.
Old 03-15-2015, 11:18 PM
Vince@Meanstreets's Avatar
yep, I'd take surgey over everything scraping on the ground.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 03-16-2015, 05:25 AM
please explain. The engine and trans cross member stays in the same place whether its lifted 2" or lowered 3".
Old 03-16-2015, 05:34 AM
JodysTransmissions's Avatar
JodysTransmissions JodysTransmissions is offline
The Legend700 will fit without any cutting of the tunnel, done them already.
Jody Haag
Jody's Transmissions on Facebook
Old 03-16-2015, 06:51 AM
rickpaw rickpaw is offline
Correct, but the rear end is not. So when the car is lowered, then the rear end comes up, and the end of the transmission has to come up as well to maintain the correct driveline angle. That's where the slicing of the tunnel begins.
Tu Ho
Old 03-16-2015, 11:10 AM
So you are correcting driveshaft angle by the tailhousing rather than changing the pinion angle on the rearend? This is the first I have heard of such.
Old 03-16-2015, 09:21 PM
It's the best way to achieve small working angles which will result in less driveline vibration with increased speed.
Old 03-17-2015, 05:43 AM
Or you can go CV joints on the driveshaft, instead of u-joints. Then most of your driveline angle issues will be solved.
Tu Ho
Old 03-17-2015, 01:18 PM
I can possibly understand such with a leaf spring or non adjustable link car. But the correct way would be to adjust the pinion angle on the rearend, right?
