Old 03-23-2015, 05:37 PM
samckitt's Avatar
samckitt samckitt is offline
Default Looking for a steam vent tube....
I would like to find one that connects all 4 spots into one, but I think it is like a unicorn.
Or, looking for one for the front two ports, that the hose connects straight up on the driver's side.
Scot
86 Monte SS
LS2/T56 Magnum
Old 03-23-2015, 05:45 PM
Ron in SoCal's Avatar
Maybe not exactly what you're looking for Scot, but C&R makes a nice unit.
http://www.crracing.com/ls-steam-ven...steam-vent-kit
http://www.summitracing.com/parts/cir-78-10000
Ron in SoCal
69 Camaro in progress
Old 03-23-2015, 05:56 PM
samckitt's Avatar
I had seen that Ron. But I'm not spending that much on it. But Thanks.
Scot
86 Monte SS
LS2/T56 Magnum
Old 03-23-2015, 08:02 PM
novahollic's Avatar
novahollic novahollic is offline
Older LS1 engines have them, but depending on what intake manifold you are running, it may not clear. I know the LS6 intake has a hard time.
Old 03-23-2015, 09:15 PM
Vega$69's Avatar
Vega$69 Vega$69 is offline
You don't need the rear steam lines. How about just using the OEM set up.
Works great and not expensive.
Old 03-29-2015, 10:39 AM
jwcarguy jwcarguy is offline
Banned
Originally Posted by Vega$69 View Post
You don't nead the read steam lines. How about just using the OEM set up.
X2
GM deleted the rear stem vents for a reason
They only used the 4 port design in early Gen III engines, then deleted/ blocked off rears due to air/ steam pockets going to highest point and purge out front ports
Old 03-30-2015, 03:35 AM
71RS/SS396's Avatar
Originally Posted by jwcarguy View Post
X2
GM deleted it to lower the production cost and lower the part content, not having the rear stem ports will work fine on a completely stock engine that only sees highway use. Once you start increasing horsepower and using the car hard it becomes necessary to have all four corners vented. I've cut trashed heads apart to look at the water jackets and you would be amazed at how bad they are. Cylinders 2&7 do not have a complete flow path around the combustion chamber so water flow is not very good on those 2 cylinders and makes them prone to developing steam pockets which leads to detonation. Imho this is why you see so many engines that blow up the #7 cylinder.
Old 03-30-2015, 08:17 AM
ironworks's Avatar
We sell these units that you could hook up at all 4 corners with -4 line and have dual steam ports put in the radiator or water pump.
http://www.ironworksspeedandkustom.c...rod/prd240.htm
Old 03-30-2015, 08:41 AM
samckitt's Avatar
Those are cool, but $50 each. Maybe there is that much machining in them to justify that cost, but I cant justify over $200 for 4 of them. I'll figure out something with stock setup. Thanks
Scot
86 Monte SS
LS2/T56 Magnum
Old 03-30-2015, 11:13 AM
ironworks's Avatar
That's a pair.
