header to fuel lines clearance
Looking for opinions on how close I can safely have my headers to my fuel lines. I'm going to make it so the header is as far away as I can get it from the fuel lines. However, they are on the lower portion of the firewall so they run through the same area as the header. I'll probably wrap or cover the fuel lines with high temp sleeves as well just because I like to be safe. So, what say you about how close you'd have a primary tube to the fuel lines?
I have Earls Prolite 350 lines.
