Old 03-26-2015, 12:29 PM
patoke patoke is offline
Default 2006 track/Street Corvette Z06
Item Location (City/State): Martinez, CA
Price:$58,000 OBO
Description:
2006 Corvette Z06 for sale. Professionally built. This car is in showroom condition and has been built to the finest level of detail and craftsmanship. It has been well sorted and used for 1 track day at Thunderhill. The car has had about 1,200 miles put on it since the modifications were completed!
This is a rare opportunity to own a professionally built and sorted car for a fraction of the original build cost.
The exterior and paint are in impeccable condition. The interior is in showroom condition with the added Sparco EVO seats, Sparco belts, and harness bar. (Stock seats are also included if desired)
Engine has been completely replaced and was built with not only performance but also reliability in mind. We started by removing the old LS7 and installing one from a 2010 Z06 with 1,700 miles on it. Then we installed the best cylinder heads on the market, the Mast Motorsports Black Label 305 cylinder heads. From there we installed a LG Motorsports G7x3 camshaft, Comp timing chain set, Comp pushrods, ported high volume oil pump, complete ARE dry sump system to ensure there would never be any oiling issues, and much more which is all listed below. This engine makes 560 whp on the dyno and is a blast to drive! Dyno sheets included. The tune is for 91 octane.
For the drivetrain we equipped the Z06 with the best transmission on the market, the RPM Transmissions level 4 TR6060 with hardened main shaft. The differential was rebuilt to level 4 specifications with 300m shafts. We then had Abel Chevrolet completely rebuild the torque tube assembly, changed all the bearings, added a new throw out bearing, pilot bearing, a remote clutch bleeder, and a Centerforce DYAD twin disc clutch which drives like stock.
The cooling system has been extensively modified for track use. We started with a Dewitt's aluminum radiator that has an integrated oil cooler, then we modified a new Zr1 oil cooler for use with A/N -10 hoses and routed the engine oil through that. The differential and transmission have custom fabricated rear mounted air to air coolers which are located in the rear diffuser and provide the ultimate in cooling.
Suspension was is completely sorted and features LG Motorsports Bilstien coilovers, LG Motorsports sway bars, GM performance sway bar bushings, new tie rods, and more. This car handles amazing and can run a 1:48 lap at Thunderhill Raceway.
Modification list below.
2006 Z06
Victory Red
Katech Zr1 style side skirts and front lip $649.00
Forgestar 19" and 20" wheels $2,000.00
Michelin Pilot Sport Cup tires $2,100.00
Bilstein coilovers $2,395.00
Lg swaybar system with quiet end links $995.00
2010 Ls7 with 1,700 miles $10,900
ARE drysump pan $1149.00
Ported and shimmed oem 2010 oil pump $488
ARE dry sump oil tank $980
ARE oil tank breather $89
ARE Remote filter adapter $189.00
Katech oil line system $649.00
Modified new OEM oil cooler for AN fittings $675.00
Mast Motorsports Black Label Cylinder Heads 305 $3350.00
Lg motorsports G7x3 camshaft $549.99
Comp 4130 pushrods $129.00
Comp timing chain $189.00
Comp trunion bearing upgrade $215.00
ARP head bolt kit $195.00
GM MLS head gaskets $90.00
LG carbon intake system $529.00
LG super pro long tube header system $1499.00
LG high flow cats $400.00
LG X pipe -included with headers
NGK TR6 Spark Plugs $45
Dewitt's aluminum radiator with oil cooler $749.00
Centerforce DYAD Twin Disc clutch $1699.00
LG remote clutch bleeder $145.00
Rebuilt torque tube assembly by Abel Chevrolet $1150.00
RPM transmissions Level 4 TR6060 trans $5,500.00
Rebuilt level 4 differential with 300m shafts. $1750.00
Fabricated rear mount diff and trans coolers with Fluidyne coolers. $2,290.00 with labor
Sparco EVO seats $1,600.00
Sparco Hans compatible harnesses $940.00
Harness bar $655.00 with labor
Seat mounts $550.00 with labor
Parts total not including tax or shipping $47,476.99
Labor:
Remove old Ls7 and install low milage Ls7 with ARE dry sump, new oil pump, Centerforce DYAD clutch, Rebuilt torque tube, RPM transmission, Blu808 differential,
ARE dry sump tank, ARE remote filter, LG remote bleeder, Aluminum radiator, new modified oem oil cooler, Katech oil lines, LG long tube headers with high flow cats and X pipe,
New oem water pump, new belts, Mast cylinder heads, LG camshaft, pushrods, rocker upgrade, ARP bolts, MLS head gaskets. $9,890
Remove OEM suspension, install LG Sway bars, Bilstein coilovers, Quiet end links, Stoptech Trophy brake kit, Bleed brakes and fill with ATE fluid. $1425.00
Install harness bar, sparco harnesses, Sparco EVO seats. $1100.00
Performance alignment $189.00
Dyno tune $500.00
Total not including tax or shipping for parts $60,580.99
If you are looking for a great track car that is also able to be driven on the street and on long trips then this is it. The navigation, ac, heater, power windows, and everything still works perfectly.
The car is located in Martinez CA and can be viewed and inspected in person.
