Old 06-20-2006, 05:49 PM
syborg tt's Avatar
Default 1991 Pro Street GMC Syclone
I know it's pro street but you could easily swap for the new 20" Mickey's and make it look awesome. I've just plum run out of money to finish this project with my buddy Caleb.
This is an original 1991 GMC Syclone originally from Texas.
The body is rust free with the Addition of two New Fenders.
The bed has already been tubbed to accept the massive
rear tires. If Pro Street is your goal this truck is different
and will attract the attention of everyone that see's it.
Our goal was to copy the look of this Pro Stock Stock Syclone http://www.sportmachines.com/gallery/91Sy2158
at a fraction of the cost and make it completely drivable.
As you can see from the pictures http://www.sportmachines.com/gallery/91sy1699
we have the stance complete and all you need to do is paint i
t and complete the drivetrain and it's done.
Here are the specs:
Paint & Body
91 Syclone - Texas Truck
Cab - Rust Free
Stock Doors - Rust Free
Core Support (1st gen will need to be modified to mount grille)
New Fenders
Stock Hood
GM Grille - Red GMC Letter
S10 bed with tubs installed (still need center hump sheetmetal)
Ground Effects & Cladding
Fiberglass Front Bumper Cover with intergrated Bumber Support
Front Wheel Arches
Syclone Rockers
Syclone Door Cladding
Front of Bed Cladding
Wheel Arches
Back of Bed Caldding
Rear Support
Rear Bumber Cover
Interior
Dash Board - No Cracks
Glove Box Door - No Cracks
New Headlight Switch new in Box
Syclone Dash Suround
Syclone Cluster w/Harness
Syclone Seats
Carpet - Brand New
Back Wall of Cab carpet
Factory Wire Harness
Wilwood Master Cylnder
Wilwood Front Disk Brakes
Wilwood Rear 12" Pro-street Disk Brakes
Chassis
Stock 2wd* Front Frame Section
Back Halved and boxed
Jegs 12 Point Roll Cage (unassembled)
Front Suspension
Spohn Lower Control Arms
Adjustable Coil Over Kit
Aim Industry Upper Control Arms (Modified for Lower Stance)
Bell Tech 2" Drop Spindles (modified to accept wilwood brakes)
Rear Suspension
Art morrision custom 9" housing with adjustable ladder bars and shock mounts
Koni Aluminum Coil Overs
Panhard Rod with poly ends
Strange SS axles
Wheel & Tires
15 x 14 Weld Pro-Stars w/ 31 - 18.50 Mickeys
15 x 6 Weld Pro-Stars w/
Price is $6500.00 and the location is Rockford, IL
marty-mj
