Old 04-10-2015, 10:18 AM
carbuff's Avatar
carbuff carbuff is offline
Default FS: 5th Gen Camaro Fuel Pump Module (Vaporworks style pump)
Item Location (City/State): Austin, TX
Price: $95 shipped
Description: I have a Rick's Tank with the Vaporworks setup, including the 5th Gen Camaro fuel pump. I have reached a point where I'm on the edge of the HP capabilities of this pump (650 - 675), so I just replaced it. This unit has 3800 miles on it and was working perfectly.
If you are thinking about ordering one of these Rick's tank setups, I recall the pump being an additional charge. Save a few bucks with this one.
Boxed up and ready to go, I did forget to snap a picture first, but can if really needed.
Old 04-10-2015, 10:25 AM
ViperBlue68's Avatar
ViperBlue68 ViperBlue68 is offline
Location: Yuba City, CA (about 1/2 hour North of Sacramento)
Part#? Very interested
J.T.
Old 04-10-2015, 10:30 AM
carbuff's Avatar
AC Delco M100080 I believe...
Old 04-10-2015, 12:05 PM
cwylie cwylie is offline
My understanding is vaporworks modifies the pump to use the internal regulator so its not a straight out of the box GM part. But you are correct I think they want $250-300 for the pump from ricks so this is a good deal.
Old 04-10-2015, 03:05 PM
1nastyZ06 1nastyZ06 is offline
Are you making those HP numbers to the wheels or flywheel? I'm making about 540rwhp and 520rwtq. Would that be pushing it with this pump?
Old 04-10-2015, 03:42 PM
carbuff's Avatar
I thought I read something about them modifying the pump also, but when I bought the replacement, Carl said I just needed to stick it in the tank. Which I did.
I'm making 540 to the rear wheels. I was concerned because I drop some pressure on my gauge as the RPM climb. Well, come to find out, I'm doing the same thing with the new pump I replaced it with, so it may have been a worthless switch for me. My gauge and my Holley both measure the pressure at the fuel rail while the PressureWorks controller I have measures close to the pump. Since I'm seeing the same effect with the new pump (the larger one), I think the pump was fine for my power level (the injectors never went to 100% Duty Cycle, so they weren't maxed out).
Anyway, you are close to the limit as I was, I switched for some insurance if I grow again in the future.
Old 04-11-2015, 01:14 AM
Is this the factory 5th gen pump or the ZL1 pump? I thought they were using the ZR1 pump. If it's the ZL1 pump I will take it. Just need your PayPal address.
Wes
Old 04-11-2015, 07:14 AM
Jdseeling Jdseeling is offline
I will take. send me your email I will send Paypal now. I already spoke to Rick's in length and this will work. Sending you a PM Thanks David
Old 04-11-2015, 09:11 AM
carbuff's Avatar
Wes, this is not the ZL1 pump, it is the SS/1LE 5th Gen Pump.
David, looks like I just received the payment. Thanx! The pump is sold...
