Old 04-13-2015, 10:40 AM
jeds jeds is offline
Default ls7/lsa/stroked ls3/other?
I'm going to be ordering a motor in a couple months and am a bit torn on what to choose. Plans for the car are 80% street 20% track. Even though it's mostly a street car I still want to be somewhat considerate of weight.
The car is a 69 Nova with full dse suspension, T56 magnum, and 9" rear. Looking to make mid 500s rwhp but I'm more interested in getting the torque numbers up there. I know all of these engine selections will need some changes to get me there but I think all those changes are within my budget.
I'm sure opinion threads are probably annoying... but any suggestions are very much appreciated. I'm sticking to LS family only as that is what the car is built around.
Old 04-13-2015, 01:27 PM
DavidBoren DavidBoren is offline
Out of everything you mentioned, I would choose the LSA. For one, it's impossible to argue with the torque delivery of a positive displacement blower. Secondly, it's good enough for the Cadillac CTS-V. And third, you can always stoke it to 408ci with a 4" crank if it's not enough "as is".
Old 04-13-2015, 02:19 PM
gmorris gmorris is offline
To me there is too much of an LS7 tax to really consider one at this time. I went with a TSP 418 LS3 that I'm very happy with and did not include any parts I couldn't use (ie no changing pans or front drives and the ecu and harness are complete and turn key). Makes 630 fwhp and has great street manners. An LSA is also a great option but I felt the initial price is significantly higher than an equal powered stroker once all was done.
Old 04-13-2015, 07:10 PM
The ls9 is pretty close to what I am shooting for, but the price is a hard pill to swallow...
Or maybe that's over kill for my use and the lsa with a pulley swap and some other bits would suffice? No forged internals though...
I wonder if sourcing a forged long block and using the ls9 blower or some other tvs2300 unit would be semi-comparable price wise?
Old 04-13-2015, 07:20 PM
Schwartz Perf Schwartz Perf is offline
Supporting Vendor
You don't really need all the forged internals for 650-680 engine hp with a supercharger. Just add valve springs and ARP rod bolts at a minimum!
BTW, the LS9 has a $2000 GM rebate going on until the end of June
-Dale
SchwartzPerformance
Where classic style meets modern technology.
SchwartzPerformance.com
GMachineChassis.com
LSxEngines.com
Facebook | Instagram | YouTube
Old 04-13-2015, 07:41 PM
Flash68's Avatar
Flash68 Flash68 is offline
Just see if this is still available.
https://lateral-g.net/forums/showthread.php4?t=48786
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 04-14-2015, 11:58 AM
I was thinking that you could probably get a LSA pull-out from a CTS-V for cheaper than any of the other options. And that gives you the oem supercharger right off the bat.
If you are buying new, or have the budget to buy new, then I would go with a stroked LS3. If you can achieve your power goals with a naturally aspirated engine, you should probably do that.
Old 04-14-2015, 11:03 PM
ironworks's Avatar
Stock LSA will put 570 to the ground with a factory Gm performance parts tuned ECU.
