Old 04-15-2015, 10:10 AM
JohnUlaszek JohnUlaszek is offline
Default NEW -- IIMuch Airport AC Bulkhead System
The II MUCH Airport AC bulkhead was designed to dramatically reduce the effort required to route EZ-Clip lines through the firewall when installing Vintage Air AC systems.
All four lines fit through a 2.5" hole
Because fittings are eliminated there is no need to allow for wrench clearance
With EZ-Clips tight bend radius packaging options are improved.
Hoses can be passed through without removing hose ends
Airport seals against the outside diameter of the EZ-Clip hoses
Includes an adapter for the heater control valve to adapt form EZ-Clip to heater hose
O-Ring interface seals against the firewall
Anodized 6061-T6 Aluminum
Old 04-15-2015, 01:34 PM
Vega$69's Avatar
Vega$69 Vega$69 is offline
Does this work with reduced barrier lines?
Old 04-15-2015, 01:48 PM
It was designed specifically for use with EZ-Clip. What is the diameter of the lines you're referring to?
Old 04-16-2015, 10:18 AM
gray776's Avatar
gray776 gray776 is offline
Cool new product John!
Old 05-15-2015, 10:33 PM
CarlC CarlC is offline
Nice to see the final product. Great work John.
http:www.vaporworx.com
Old 05-16-2015, 04:00 PM
Bsinclair Bsinclair is offline
can the bulkhead be ordered in all black anodizing like the cad drawing? i went to order 1 and there were no options..
Old 05-16-2015, 10:08 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
I would also like to know.
Curtis
Old 11-06-2015, 11:49 AM
Sorry I missed your questions. Yes, it can be ordered black on black. There is a drop down menu that lets you choose between black and silver.
http://www.iimuch.com/collections/ac...ant=1296491376
