Old 04-25-2015, 08:00 AM
paulk68 paulk68 is offline
Default What Idler arm with Tru Turn
Hey guys, I have a 68 camaro that will be running the complete ridetech front suspension with tru -turn. I have read that using a 67 idler arm will help with header clearance since it is a longer arm can any one confirm that. Are there any issues using a 67 idler on a 68.
Old 04-27-2015, 11:34 AM
DavidBoren DavidBoren is offline
If you are using a complete RideTech package, then I would definitely call RideTech, or maybe Brett (?) will chime in with some professional/technical/expert advice.
Old 04-27-2015, 12:45 PM
rodney@ridetech rodney@ridetech is offline
The 67 Idler arm is the longer of the 2 but, the 68-69 idler is easier to get. The Idler Arm is mounted on the frame at and angle so, it will move it down and forward at the same time and ,typically, its not enough to clear a header that might be hitting. Do you have your headers for your car already? If so, what engine and what headers?
Old 04-27-2015, 02:04 PM
cwylie cwylie is offline
Yes I can confirm the longer idler didnt really help header clearance. I tested both but ended up running the 67 because I figured at least both arms were the same length that way.
Old 04-27-2015, 03:08 PM
I think I am going to run the mid lenght hooker headers, to avoid having issues. I have the rest of the hooker LS swap kit so maybe the mid lenght headers will clear just fine. Or I might look into the ultamite headers. It sounds like i should just stick with the cheaper 68 idler arm.
Old 04-27-2015, 03:40 PM
Yeah I think the mids fit just fine. I ran the long tubes and had to modify one tube.
Old 04-27-2015, 04:39 PM
Thank you very much for the info!!!
Old 04-27-2015, 07:27 PM
SlowProgress's Avatar
Pozzi's site has some good information. Here is a link in idle arm area. He has some part numbers in there along with general information.
http://www.pozziracing.com/camaro_st...eering_linkage
Old 04-28-2015, 03:59 AM
Thanks guys for the help, I think I am just going to order the hotchkis idler arm for my 68. looks like a solid stock replacement.
