Old 04-27-2015, 12:08 PM
DKz Garage's Avatar
DKz Garage DKz Garage is offline
Default What throttle cable?
Looking for some input on what throttle cable to use. 69 Camaro with LS3, FAST 90mm throttle body (drive by cable). I know I have to make a bracket to mount the cable on the intake .... what Lokar (or other option) cable should I use?? I have a Lokar billet gas pedal. The cable must have a barrel nut to fit into the hole/slot in the throttle body.....
Thoughts??
Old 04-27-2015, 12:21 PM
snappytravis's Avatar
Thoughts??
I think I have the same throttle pedal, I used this part Lokar TC-1000LS1U hope this helps, It is a 36 inch cable. You may not need one this long It can be cut down if needed. Good luck..
Old 04-27-2015, 12:42 PM
DKz Garage's Avatar
Thanks.... I will pursue that as an option.
Old 04-27-2015, 08:18 PM
Vega$69's Avatar
Vega$69 Vega$69 is offline
X2 on the Lokar
Old 05-05-2015, 09:51 PM
Brewtal66 Brewtal66 is offline
I just used a Lokar cable as well. I thought about getting a bicycle brake cable, but there's no good way to adjust it, or shorten it.
They make them with black sheathing as well, which is what I went with. I believe they can make them any length. I got one that's 48" long.
Editor, Lateral-G
[email protected]
Old 05-06-2015, 09:49 AM
jwcarguy jwcarguy is offline
Banned
X3 on the Lokar cable
But Holley sells a throttle cable bracket that you can use with the GenIV 4 bolt throttle body
here is a pic of my engine that I am using a LS3 intake manifold and Edlebrock DBC TB
Old 05-08-2015, 04:07 AM
cjsgarage cjsgarage is offline
What ECM are you running?
I've understood it that you have to go backwards to run cable throttle body on LS3. Which means getting a 24 tooth reluctor for the cam and running the LS1/6 style computer.
Not to burst your bubble. I actually prefer drive by wire because of the ease of setting up cruise control. Two buttons and bam, cruise. Not like cable. You have to install another module and another cable at minimum.
Old 05-08-2015, 07:46 AM
cwylie cwylie is offline
Any pics of how it comes through the firewall? I dont think my car has the hole for it.
Old 05-08-2015, 08:00 AM
Banned
here are pics of mine using the Lokar cable
Old 06-01-2015, 04:42 PM
Any idea what size bolts are use to attach the throttle pedal to the floor board?
