Old 04-30-2015, 07:57 AM
fleetus macmullitz's Avatar
Default 427 cid 800hp n/a LT-5 build
Saw it here...
http://www.zr1.net/forum/showthread.php?t=24966
Old 04-30-2015, 09:28 AM
DavidBoren DavidBoren is offline
Thanks for sharing that.
Those Corvette Lotus engines are neat. I like how the guy building it said that it costs "cubic dollars" to upgrade an LT-5.
Did the LT-5 have a flat plane crank? I don't think it did, but I'm not sure.
Old 04-30-2015, 10:21 AM
David,
Although it wasn't a flat plane crank, there was a racing LT-5 or 2 that was built with a flat plane crank. Might have been 5.0L versions.
Old 04-30-2015, 04:36 PM
Flash68's Avatar
Flash68 Flash68 is offline
You know I love it Skipper!
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 04-30-2015, 07:08 PM
800 hp n/a SB2's and LT-5's...I guess that could give those FE guys something to dream about.
lol
Old 04-30-2015, 08:30 PM
That's amazing! I had no idea you could build an LT5 to that power level.
Old 04-30-2015, 09:54 PM
Plus they look amazing too, especially with the siamesed plenum mod.
Old 05-02-2015, 02:32 AM
Solid LT1 Solid LT1 is offline
Those motors weight about the same as a cast iron big block....wouldn't touch one with a 10ft pole....starter motor is under the intake manifold....British engineering at its finest!
Old 05-05-2015, 03:07 PM
I am just a huge proponent of having overhead valves with one cam to rule them all. That's just personal preference, though.
I do find it quite funny that the LT-5 is what GM produced in the 90's when they decided to see what overhead cams had to offer. And it made 400hp back in 1993-ish. It took Ford until 2011 to make a 400hp dohc naturally aspirated motor.
I am glad that GM stuck the cam back in the block where it belongs... I think that the choice to build the LS motors versus pursuing the dohc design has more than proven to be the right move.
Old 06-20-2015, 12:11 PM
uxojerry uxojerry is offline
The LT5 was built mostly by Mercury Marine and is viewed by many as an outstanding design. Gm couldn't machine the parts to the tolerances required and farmed the work out to Mercury. It was discontinued because of cost and not because it was flawed. Same story with the Northstar, 32 valve V8 built by Cadillac. Great engines but discontinued due to cost.
I like 2 valve motors because they are small, powerful engines and look good on an engine stand. I almost put one in my living room, lol. Take a look at a Coyote on an engine stand, it is big, top heavy, and ugly. The Coyote does sound great when it's having the snot wrung out of it.
