Old 05-14-2015, 09:15 AM
RoadRace Elco's Avatar
RoadRace Elco RoadRace Elco is offline
Default how does the knob come off the rod????
I am interested in changing my factory knobs on my El Camino to the Ridetech billet, i know the wiper will come off as i see a set screw, but its the headlight that is confusing. i know how to remove the knob with the rod but how do i remove the knob from the rod?
1966 El Camino
383 500hp at flywheel
Keisler SS700 5 speed
Mass-Flow Injection
12 Bolt 3:73
Speed Tech full suspension
Ride Tech Coil Overs
Rushforth 18's
Wilwood 6 piston with 14" rotors
Old 05-14-2015, 10:19 AM
I almost believe they were injected when they were made....pull the rod and cut off the knob ?
( god that sounds so wrong).
Old 05-14-2015, 11:57 AM
1966 El Camino
Mass-Flow Injection
12 Bolt 3:73
Rushforth 18's
Old 05-25-2015, 02:00 AM
Vince@Meanstreets's Avatar
Originally Posted by RoadRace Elco View Post
You can pull the whole shaft out and replace it with a knobless shaft.
Help! makes a kit and you can just use the shaft Or cut the old plastic knob off exposing the shaft.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 06-18-2015, 03:25 PM
minendrews68 minendrews68 is offline
Feel around the top go your light switch and you'll find a pin thats spring loaded. pull out the light switch knob until it stops, then push down on the spring loaded pin and finish pulling the knob out. But, remember, when you pull the knob out, your lights will be turned on.
