Go Back   Lateral-g Forums > Classifieds > What's it Worth
Old 05-19-2015, 12:49 PM
Roe's Avatar
Roe Roe is offline
Default Value of 2015 GMC L83 5.3 LITER ALL ALUMINUM
What would the value be for this LS engine? 2015 GMC L83 5.3 LITER ALL ALUMINUM. ENGINE IS A 355 HORSE LS BASED GM SMALL BLOCK
2015 GMC SIERRA 1500 Z-71 ALL TERRAIN.
And what would it cost to turn this into a 500hp engine?
Thanks in advance!!
Old 05-19-2015, 03:26 PM
Che70velle's Avatar
Is this a crate engine, or a super low mile pullout?
FEAD?
Computer?
Harness?
Thanks Dad!!
Old 05-19-2015, 04:21 PM
Roe's Avatar
Roe Roe is offline
Super low mile 6000 kms (located in Canada). Comes with ecu, gas pedal, wiring harness.
Old 05-19-2015, 08:20 PM
Che70velle's Avatar
This engine is not an LS based engine, but it's from the new LT engine family, with direct injection. Several new features make these engines desirable, and the performance aftermarket is already well invested to help guys that want more power, to obtain that. I can't really find any used engines to help you get an idea of what this is currently worth. I'd be afraid to guess, as there just aren't enough of these out there as pull outs, to know.
Perhaps someone will chime in that's seen pricing on these used LT engines...
Thanks Dad!!
Old 05-19-2015, 08:25 PM
Roe's Avatar
Roe Roe is offline
Thanks Scott and hopefully someone else will chime in.
Old 09-27-2015, 03:10 PM
KSBRKTRACER's Avatar
KSBRKTRACER KSBRKTRACER is offline
I have one listed in the for sale section for $5000.00 complete 17k pullout with a 2wd 6spd Trans.
Old 11-22-2015, 07:08 PM
Darrell ls7 Darrell ls7 is offline
Default New lt motor & trams
A wreck 2014-15 2wd truck will go for $8000-$12000 depending on the damage so $5000 for motor an trams is not out of line .trying to buy a truck for the last year for motor & trans Ecm for my 67 Camaro.
Old 12-05-2015, 10:39 AM
gnx7's Avatar
gnx7 gnx7 is offline
To make 500hp from a 5.3 and no forced induction.... won't really be possible and have it not be an all out race motor.
You would be better off buying a 6.0/6.2 or even an LS7 pullout (lots of LS7's for sale on corvetteforum.com).
I personally know the guy selling these parts.... he built my LS9 turbo motor and my LS7:
http://ls1tech.com/forums/parts-clas...ower-more.html
2014 6.0 L96 shortblock, polished cryo'ed stock crank, stock rods, stock Pistons with steel rings set for boost or nitrous. Ready to run. $1,800 local SoCal pick preferred
Aluminum LS2 block fresh long-block, bored to 4.025", new cam bearings, Forged flat top Pistons, stock rods and cryo treated polished crank, has fresh 823 ls3 style heads, 222/231 .56x lift cam, all fresh valve covers to gen 5 camaro oil pan $4,000
