Old 05-29-2015, 10:21 AM
BMR Sales's Avatar
Talking BMR Suspension New Product Release - 2" Drop Leaf Springs for 1st Gen F-body (SP057)
BMR Suspension
Two-inch Drop Leaf Spring for 1st Gen GM F-body and 3rd Gen GM X-body
Reduce wheelhop, control axle wrap, and add the perfect stance to your 1st Gen F-body or 3rd Gen X-body with 2-inch drop leaf springs from BMR Suspension. BMR’s leaf springs give you a superior option to stock leaf springs that sag, rust, and do little to control axle wrap and wheelhop as they age. Formed to exact height, arch, and length specifications, BMR’s Leaf Springs are designed to give improved performance without sacrificing ride quality. BMR’s Leaf Springs (SP057) feature a 2-inch drop, multi-leaf design, and a 190 lb/in spring rate, reducing body roll without increasing rear oversteer. The spring design, combined with precise clamp locations, give you less wheel hop and more axle control. Each spring comes with new front and rear bushings, which some companies make you buy separately. The leaf springs also come with Teflon antifriction pads between each leaf for smooth, quiet travel through the range of motion. BMR designed the SP057s for street performance, drag race, and handling applications. New front mount hardware hardware (RH015) and stainless steel shackle kit (LSS001) are available separately.
To preview all of BMR’s high-performance suspension parts, please visit www.bmrsuspension.com, email [email protected], or contact them at BMR Suspension, 928 Sligh Ave, Seffner, FL 33584, 813-986-9302, Fax: 813-986-8055.
Old 06-03-2015, 01:17 PM
Corey R. Corey R. is offline
How much additional is the heavy duty coating?
What does the coating consist of?
Old 06-04-2015, 11:22 AM
BMR Sales's Avatar
They come with the Heavy Duty Coating. What is the Coating? I would have to find out, but they are Made in the USA, so they they don't have any Banned Substances that you can find on Chinese made Springs
