Old 05-30-2015, 09:24 PM
pimlico pimlico is offline
Default Crate LSX454 surging at low RPMs
Anyone else here running a crate LSX454 with LS7 intake from Jegs?
Noticed mine is surging at low RPMs.
Did you have to tune yours?
Old 05-31-2015, 12:54 PM
I'm no LS mechanic but I've read that some big cams or larger throttle bodies can cause surging that can be tuned out.
Old 05-31-2015, 10:05 PM
canrc canrc is offline
I had a similar issue due to my cam and after consulting many, I was told that I would have to live with it because of the factory ecu -- I went with the Holley setup and now the surge is gone.
_________________________
- Raj
'69 Camaro - Current Project
https://lateral-g.net/forums/show...ighlight=MAX-G
Old 06-01-2015, 06:55 PM
Did you have a crate LSX454?
Who did you get to sort out the tuning with the Holley setup? Did you use the dominator? Was it an easy fix?
