Old 06-05-2015, 07:41 PM
67txcamaro 67txcamaro is offline
Default 4l60E question
I have a 67 Camaro with 5.3 and 4L60E trying to install lokar floor mount shifter do i need the neutral safety thing on the side do i just remove it?
thank you for helping me out
Old 06-08-2015, 05:18 PM
ok it looks like i dont need it. I removed the nut and the arm and remove the plate.
Old 06-08-2015, 05:51 PM
Z06vette's Avatar
Z06vette Z06vette is offline
Unless its physically unable to be used, I would definitely keep it. I have never used that shifter, but I have done 3 builds with the factory 67 floor shifter. They are a tight fit but I was always able to get everything to work. Any reason you want to remove it?
69 RS LS3/T56
68 firebird vert LS1/4L60E
67 RS LS2/T56
Old 06-10-2015, 05:21 PM
i dont know what it is and it look like it was going to be in the way. the plate has two connectors on it..
Old 06-15-2015, 11:29 AM
n77nxc's Avatar
n77nxc n77nxc is offline
I installed it on mine and wouldn't recommend taking it off. If you plan on using a new wiring kit from a company like American Autowire, their harness includes the connection for that switch.
Also, you will need to purchase a similar switch to operate your reverse lights. That switch will be mounted to the linkage on the trans.
1967 Camaro - Project "Resale Red" - Sold to 175RGR
