Go Back   Lateral-g Forums > Vendor Specific Technical Discussions and Support > Speedtech Performance USA
Old 06-10-2015, 09:11 AM
Ben@SpeedTech's Avatar
Default Speedtech's official ExtReme announcement
If you haven't heard the buzz yet, Speedtech Performance has pulled out all the stops in moving forward on a quest after the best suspension geometry on the market. Teamed up with Ron Sutton we've conquered the challenge to develop an industry first suspension that works fantastically in low, mid, and high travel strategies, and has killer geometry numbers across the board. Intended to push the Pro Touring world to the next level, this suspension is designed to allow up to 315mm tires up front and takes full advantage of that huge contact patch! Check out this official press release copied below, and feel free to ask any questions, we and Ron are happy to share more insight and specifics...
"Looking for the Best of the Best? Search no longer! Through years of street and track testing our products, Speedtech Performance has taken all we've learned and invited veteran road race chassis builder Ron Sutton to join in creating a totally new, hardcore Pro Touring suspension. The exciting result is our new line of "ExtReme" chassis products.
Using the latest in computer simulation, all aspects of this suspension's geometry were calculated and tested until the best possible numbers were achieved. Said Ron, "This design makes this the best handling, steering & driving suspension available, an upgrade from frankly any chassis or subframe in the Pro Touring market today.”
Featuring an industry first, we've achieved optimum roll center for low, mid and high travel strategies. Our frame's rack location and new ATS forged-in-the-USA ExtReme tall spindle provide optimum Ackerman with up to 30 degrees of steering angle using 315 mm wide tires! This combination provides reduced KPI/SAI angle, significantly less scrub radius, achieves optimum tire slip-angles, requires less caster for optimum tire contact patch and increases front tire grip up to 20%. Increased shock length has 0.78 motion ratio for faster response, precise control and more suspension travel with virtually ZERO bump steer - .005” throughout full travel range!
What does this all mean to you? Whether you're on the street or at the track, you'll have a better handling and better riding vehicle than has ever been achieved before. Production of the C10 chassis is ready to go and the Chevelle, Camaro, Nova, and Tri 5's are right behind. Learn more about this incredible suspension for C10s, Camaros, Chevelles, Novas and Tri-5s by calling 435-628-4300 or Clicking Here. You can see our ExtReme products in person this year at SEMA 2015, booth # 72004."
-Ben, Creative Director
