Old 06-26-2006, 03:29 PM
LS1NOVA LS1NOVA is offline
Default manual or power steering??
Right now I have the car setup for manual steering with a stock manual box. The front tires are 245/45/17 and Im concerned its going to be a bear to steer. Will a s-10 box and a ls1 pump work ok for the street with maybe some
track time. What would be the best steering box on a budget(used or less than $150)
:Its a 71 Nova with the stock subframe and a turbo 6.0. I think I could fit a LS1 pump in the stock location.
Nate
71 Nova. "The Green Machine" April 11' PHR
Old 06-28-2006, 10:48 AM
Anyone?
Nate
Old 07-11-2006, 10:46 AM
avitet avitet is offline
i dont know weather or not they will work but i look at using a third gen camaro box but if you want to use an s10 box look for one from a zq8 they both have a quicker ratio then the standard s trucks but id try the manual sterring first and see how bad it is rember a lager wheel can give you more leverage besides most gm manual sterring boxes have a high enough ratio to make it easy
Old 07-13-2006, 12:36 PM
MaxHarvard's Avatar
I have manual right now... its only a pain when you are turning at a dead stop... anything above 2 miles per hour, the thing turns easily.
Old 05-24-2007, 02:11 PM
Jr's Avatar
Jr Jr is offline
Did the ls1 pump work? Any other progress pics? Can we get a full picture of the engine with piping?
on the build
Old 06-19-2007, 08:12 AM
Decided to leave the manual steering on it for now and see how it is. The engine is all apart for machine work now, so I dont have any more pics.
Nate
