Old 06-28-2015, 06:27 AM
vstol vstol is offline
Default Auto meter guage adapters
I have a LS-3/427 and with Auto meter gauges. What adapters do I need for the oil pressure and water temp gauges. I assume the ones that come with the car will not work, correct? Thanks
Old 06-28-2015, 07:00 AM
Z06vette's Avatar
Z06vette Z06vette is offline
I believe its 2277 & 2268. Sometimes you can find them packaged together on ebay
69 RS LS3/T56
68 firebird vert LS1/4L60E
67 RS LS2/T56
Old 06-28-2015, 07:56 AM
QueenCitySpeed QueenCitySpeed is offline
Default LS install kit
I always order #5284. It has both adapters (coolant & oil press), a short coolant temp sender, and a pull up resistor for the tach.
Old 06-28-2015, 05:28 PM
Great last question what about the oil temp gauge and pressure and where do I get that from? Thanks
Old 06-29-2015, 12:48 PM
Autometer offers oil temp gauges in just about every style they build. I like to mount oil temp senders in C5 Corvette locations. You can use the same coolant temp adapter to install it.
Old 06-29-2015, 05:03 PM
Thanks I have the autometer oil temp gauge just wondering if I can use their setup. Thanks
