Old 07-03-2015, 06:05 AM
jlwdvm jlwdvm is offline
Default ECU dual fan wiring?
I have a Speartech stand-alone harness for my LS3. I will be running dual fans and my ECU has a pair of wires coming out of it for each fan. My question is where does each fan wire coming out of the ECU go? The relays for the fans have a single wire labeled as sending unit.
Old 07-03-2015, 07:16 AM
dontlifttoshift's Avatar
That's where they go. ECU is the sending unit, providing a ground signal to turn the relays on.
Donny
Old 07-03-2015, 08:54 AM
Right, but there are 2 wires for each fan coming from the ECU harness. Do both wires go to the single fan relay sending unit wire, or is one a ground? One wire is striped and one is solid for each fan.
Old 07-03-2015, 10:49 AM
Vince@Meanstreets's Avatar
Each wire is a circuit for a relay. Should have one relay for each fan. Sounds like your relay set up is wired direct. But sending unit maybe referring to a block switch. No instructions?
excellent set up here to remove the guess work:
http://www.entropyrad.com/lsx-series...ontroller.html
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 07-03-2015, 12:11 PM
I have 2 AAW relays to use that were recommended by C&R (Built my rad with dual Spal fans for 69 F-body with LS)...one for each fan. My question is where do I run each of the 2 wires for each fan (4 wires total coming out of the ecu wire harness)? Maybe I have the wrong style relay?
Old 07-03-2015, 12:21 PM
ok gotcha....
grounding circuit shared with switches. repeat for second fan
Dealer for
NEVER FORGET -11
Old 07-03-2015, 12:43 PM
Right...that looks similar to the directions that came with the relays. My question is: why dies my ECU harness have 2 pairs of wires coming out of it instead of 1 wire for each fan? Is one for a manual switch and one for a temp sensor switch? I tried to get a hold of Speartech, but no answer.
Old 07-03-2015, 01:01 PM
Can you turn the key on. I think speartech gives you a 12 volt wire as well, I have only used his harness once.
One wire would go to 85 and one wire would go to 86 on the relay.
Found this http://www.speartech.com/v/vspfiles/...ns/LS58X4L.pdf
Donny
Old 07-03-2015, 01:11 PM
BINGO! Thanks!
