Old 07-08-2015, 01:54 PM
Mickav6 Mickav6 is offline
Default ls7 tr6060??
I'm Building a 68 Camaro with an LS7 and found a great deal for a GT500 tr6060, Someone know if it's a big deal to match the two?!
Thanks!!
Old 07-08-2015, 02:33 PM
And tr6060 is basically a t56 magnum...the issues could be bell housing which you would need one for a gm engine. The other would be possibly having to change the input shaft as the spline count could be different. The tail shaft would be the same unless you get a custom driveshaft made. Now I'm sure I'm missing some details but those are the main ones as far as I know
Old 07-08-2015, 03:38 PM
Ron in SoCal's Avatar
Ryan I believe you're right on the input shaft.
Ron in SoCal
69 Camaro in progress
Old 07-08-2015, 04:45 PM
thanks guy's, i need more homework on this before to buy!! I got it for 700$ tho.. maybe worth some work!
