Old 07-10-2015, 08:18 AM
RS-Chris's Avatar
RS-Chris RS-Chris is offline
Supporting Vendor
Default Roadster Shop SPEC series debut
We are pleased to announce the debut of the all new SPEC series chassis from Roadster Shop.
With the Goodguys Columbus show this weekend, we are debuting the first two chassis in a lineup that will cover Chevelle, Camaro, C10, Tri-five and Impala. If you are at the show, make sure you stop by the booth and take a look at the Camaro and C10 SPEC series chassis on display.
"All well and good" you may be saying at this point. "It's a Roadster Shop chassis so it must be expensive, right??"
Here's the best part: all SPEC chassis start at $9895
So what is SPEC? Simply put, SPEC is the most advanced, highest quality chassis and suspension system available for a low budget.
The Benefits:
  • No kinks, bends or stressed areas that are prone to flex like mandrel bent tubing
  • Ability to contour to stock floors for no floor modifications on most applications
  • Stronger, lighter, and more precise.
  • CNC located factory mounts built into the frame for easy, vehicle specific installation
  • Frame rail designs to accommodate mini-tubs and up to 12” wide wheels
SPEC Series Chassis Standard Features:
  • RS exclusive “Laser Rails” precision CNC laser cut and contoured
  • Vehicle specific body mounts, bumper mounts, and other factory mounting locations
  • Crossmembers and chassis bracing to contour to factory floors allowing 3” exhaust
  • LS Engine mounts
  • Adjustable transmission mount accommodating all popular transmissions
  • Power rack and pinion steering
  • Easy to adjust upper a-arm eccentric mounts for fast and accurate alignments
  • Performance billet coilovers or air bag suspension
  • Wilwood dropped “Pro-Spindles”
  • Ford 9” housing with 31 spline axles
We will be posting more updates as we fulfill the full lineup after the initial debut so stay tuned!
Some intro to SPEC:
Spec '67-69 Camaro: http://roadstershop.com/product/full...-spec-chassis/
'67-72 C10: http://roadstershop.com/product/full...-spec-chassis/
[B][FONT="Arial"]WWW.ROADSTERSHOP.COM
Old 07-10-2015, 08:22 AM
nicks67ca nicks67ca is offline
Holy cow........
This is insane! Can you retro fit your current rear end? Will you offer SBC mounts? (first gen Camaro?)
Edit i see the 9" housing and axles included center section isnt?
Old 07-10-2015, 09:13 AM
CamaroMike's Avatar
CamaroMike CamaroMike is offline
That is one solid deal!
Alabama
1969 Camaro
1978 Camaro
Old 07-14-2015, 08:59 AM
RS-Chris's Avatar
Supporting Vendor
Post
Originally Posted by nicks67ca View Post
Holy cow........
Thanks!
We will be offering SBC mounts or LS mounts with the chassis.
Gearing on the rear:
Rear End Gears (3.50 - 4.11 Ratio) Open: $695
Rear End Gears (3.50 - 4.11 Ratio) With Trac Loc Posi: $1350
Old 07-14-2015, 09:00 AM
RS-Chris's Avatar
Supporting Vendor
Some more detail info:
Old 07-16-2015, 11:13 AM
steveracer33 steveracer33 is offline
Default A body 65 lemans
I currently have a ride tech air ride suspension ( shock waves) on a 65 lemans, will that system be able to be used on your new SPEC frames for a A-body?
Thanks Steve
Old 09-15-2015, 09:34 AM
RS-Chris's Avatar
Supporting Vendor
We just completed the first SPEC based video showing Jeremy going over a few of the key details on the all new SPEC 1st Gen Camaro chassis.
Don't hesitate to ask or call us with any questions on the new setup, details and features of which can be found here: http://roadstershop.com/product/full...-spec-chassis/
Old 09-15-2015, 02:53 PM
willj313's Avatar
willj313 willj313 is offline
When will the chevelle frame be available?
Old 09-15-2015, 04:13 PM
Campbellshotrods Campbellshotrods is offline
Wow, that's not terribly priced at all, something that even I might be able to do someday!
Josh Campbell- Pushing the limits of my HOA since 2011
71 Firebird- 455, Ridetech front suspension.
67 Camaro RS/SS clone, Speedtech front suspension, coilovers, soon to get LT1/T56.
82 Z28- cheapie beater, soon to get a 406.
66 Mustang coupe- 393, T-5, sold.
Old 09-22-2015, 03:28 PM
MCB Matt's Avatar
MCB Matt MCB Matt is offline
We are now setup with The Roadster Shop, incredible frames, and now at an incredible price point too!
Let us know if we can help you guys out!
MCB
MCB Parts - Matt's Classic Bowties
5360 Gateway Plaza Dr.
Benicia, Ca. 94510
866-628-8746
TEXT ONLY: 925-989-9091 (Replied 8-4)
www.mcbparts.com
Email: [email protected]
Like us on Facebook for exclusive offers, info and chat: www.facebook.com/mcbparts
Hours: Monday to Friday 8am - 4pm Pacific
We ALWAYS enjoy talking to our customers!
We have a full time staff to answer ALL Questions, Tech Support or Order Status Tracking!
