Old 07-17-2015, 03:05 PM
Swain's Avatar
Swain Swain is offline
Default 1969 Camaro
Item Location (City/State):Irvine, CA 714
Price:$49,000
Description: Posting for a customer.
1969 CHEVROLET CAMARO "Z-28" "RALLY SPORT" CUSTOM
ENGINE
383 CUBIC INCH SMALL BLOCK CHEVY - 400+ HORSEPOWER
EAGLE CRANKSHAFT & RODS J&E SRP PISTONS
PATRIOT 64CC ALUMINUM HEADS CUSTOM GRIND HYDRAULIC ROLLER CAM
BARRY GRANT DEMON "SIX SHOOTER" 3-2 BARREL INTAKE AND CARBS - 750 CFM
MSD IGNITION BOX AND MSD BILLET DISTRIBUTOR
PATRIOT CERAMIC HEADERS-MID-LENGTH 2 1/2" EXHAUST WITH MAGNAFLOW "X" PIPE & 18" MUFFLERS
TRANSMISSION & REAR END
TREMEC TKO500 5 SPEED OVERDRIVE FLOOR SHIFT TRANSMISSION - HURST SHIFTER WITH LINE LOCK
NEW CLUTCH, FLYWHEEL AND THROW OUT BEARING
3.73 CHEVY 12 BOLT REAR END WITH POSI-TRACTION
SUSPENSION & BRAKES
HOTCHKIS 2" FRONT LOWER SPRINGS & 1 1/2" REAR LOWER LEAF SPRINGS-LOWERED ADDITIONAL 1 1/4"
HOTCHKIS FOX NITROGEN SHOCKS - NEW NEW FRONT END BUSHINGS
CPP STEERING BOX 14:1 RATIO 4 WHEEL DISC BRAKES SUBFRAME CONNECTORS
WHEELS & TIRES
BUDNIK "TUNGSTEN" CUSTOM MADE BILLET WHEELS - FRONT=18X8-4.5BS REAR=18X9-5.375 BS
BF GOODRICH g-Force Sport COMP-2 FRONT=245/40/18 REAR= 275/40/18
OTHER
PAINT COLOR IS DODGE VIPER BLUE METALLIC
BUDNIK "TUNGSTEN" STEERING WHEEL - MATCHES ROAD WHEELS
FRONT & REAR OPTIONAL BUMPER GUARDS FOUR GAUGE FLOOR CONSOLE TILT STEERING COLUMN
"RALLY SPORT OPTION"-COVERED HEADLIGHTS - NEW VACUUM CANISTERS AND PARTS
BLACK VINYL TOP WOOD GRAIN DASH KIT FRONT SEAT EXTENDERS SEAT/SHOULDER BELTS
NEW CARPET WITH DYNAMAT TYPE DEADENER, NEW TRUNK CARPET, NEW FRONT SEAT FOAM
Jason Swain
Build Link 68 Camaro
https://lateral-g.net/forums/showthread.php4?t=16865
