Old 07-19-2015, 02:37 PM
bdahlg68's Avatar
bdahlg68 bdahlg68 is offline
Default Quarter panel fit
Realistically should a quarter panel fit pretty close without any clamps or is it normal to have to twist it a bit and hold it in place before welding?
Sent from my SM-G900V using Tapatalk
Brian
1968 Pontiac Firebird
1989 Ford Mustang
Old 07-19-2015, 03:26 PM
dhutton dhutton is offline
Some clamping is commonly necessary.
Don
Old 07-19-2015, 04:08 PM
bdahlg68's Avatar
And I assume that the less structure you have left the more twisting may be necessary?
Brian
1989 Ford Mustang
Old 07-19-2015, 08:47 PM
snappytravis's Avatar
It shouldn't have excessive pressure when it's on there. If so maybe some of the inner structure is bent or damaged. I used self taping screws with 5/16 head and the smallest vise grips, I think 4 or 6 inchers. Good luck
Old 07-28-2015, 07:51 PM
hiwayman hiwayman is offline
don't expect to much get the panel fitting as good as you can , then cut, slice to get it fitting , I wish I new now what I new 5mouths ago I wasted a lot of time going back and fourth ,
