Old 07-25-2015, 07:59 AM
lsuguy's Avatar
lsuguy lsuguy is offline
Default Currie/Speedtech Ford 9" Bearing Plates
I have a Ford 9" setup from Speedtech with Torino Bearing ends.
They shipped with these style bearing plates:
http://www.summitracing.com/parts/msr-9750/overview/
However the bearings on the axle do not seat completely flush with the axle housing so there is a space between the bearing plate and the face of the housing. Is there a better solution to this? Seems like there should be some type of spacer between the bearing place and the housing. I measured everything out and I am bottoming out the axles.
The bearings are already pressed on the axle. If someone can link me to what they are using that would be very helpful. I should also mention that I do not currently have my rear brakes installed. So it may be that the spacing will be taken up by the parking brake assembly?
Thanks guys!
