Old 08-10-2015, 06:45 AM
Erik Beckett Erik Beckett is offline
Default Wilwood brake fittings and flex lines??
So I just installed my Wilwood 6 piston front brakes on my 68 camaro with the full Ridetech strong arm coilover kit. I forgot to look this morning before I left for work, but I need the front flex line and the fitting for the caliper. I think its 1/8" to -3 but I am not sure. I was going to run to Jegs on my lunch hour and buy the parts.
I am not sure if the front calipers require a 90 degree or a straight fitting to connect to the stainless flex line?
Again, I should of looked but forgot to before I left the house. If anybody can let me know whether a straight or a 90 will be best that would be great. Also, how long of flex line would I need, 10-12" I assume?
Thanks, Erik
Old 08-10-2015, 10:53 AM
dontlifttoshift's Avatar
220-7056 is the wilwood brake line number and it is complete. jegs has it in stock and then you won't have to match fittings.
Donny
Old 08-10-2015, 03:12 PM
Bad94 Bad94 is offline
Your the best.
Above Average Motorsports
1972 Nova, Ride Tech, Forgelines, Wilwood, Bowler Transmission, Lingenfelter, RAFT.
