Old 08-10-2015, 03:02 PM
Default Knock sensor
Hi Can the knock sensor on the drivers side of my LSA be clocked towards the front so the connection for it is front of the square piece on the block, or is it only able to go in this position?
Mine is pointing right at one of the header tubes and I don't think the connector will fit on it.
This is not mine it's only for reference.
As always Thanks
Old 08-10-2015, 03:15 PM
dontlifttoshift's Avatar
Yep, turn any way you want.
Donny
Old 08-10-2015, 06:13 PM
Thank you Donny. Done !
