Old 08-21-2015, 07:19 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Default Need Some Input Please
I am considering saving the door locks on my 67 and going with keyless entry like many modern cars now have. I'm not really up to speed on these systems and the options out there right now or which one(s) are better than others.
If you've used one, are planning to or just know a bit about them, I'd really appreciate your input.
Thanks!!
Curtis
Old 08-21-2015, 09:52 PM
MtotheIKEo MtotheIKEo is offline
Thanks!!
I have used Autoloc components to piece together keyless entry and window control (could roll windows up or down from key fob) and the components have been flawless for 10+ years. Fabrication required for individual components though.
http://www.autoloc.com/catalog/Power...--(Up-AND-Down)
http://www.autoloc.com/catalog/Keyle...nction-Remote-
http://www.autoloc.com/catalog/Actua...-Wire-Actuator
Old 08-22-2015, 10:38 AM
Musclerodz's Avatar
MODO makes a keyless entry kit and has a specific mounting bracket for camaros.
Mike Redpath
Musclerodz & Customz
facebook page
Old 08-22-2015, 06:03 PM
Spiffav8's Avatar
Lateral-g Moderator
Thanks for the info gents!
Curtis
Old 08-22-2015, 06:15 PM
cluxford cluxford is offline
I used Modo in mine, works awesome
68 Camaro 632 BBC 800+ HP Project (600Kw)
61 Buick Lesabre Bubbletop (daily driver)......miles of smiles
Old 08-22-2015, 08:05 PM
I like the idea. However, I'd put a fail safe system in the car like most modern cars have. A keyed trunk lid with a manual cable to the drivers door.
My C6 had it and I quickly understood why. The keyless system was not great and I did lock the remote in the car at one point. I was able to use the key to pop the trunk and pop open the drivers door with the cable.
Otherwise, you run the risk with an enclosed trunk of having a cock pit you simply can't access without breaking a window.
