Old 08-27-2015, 06:17 AM
workng247 workng247 is offline
Default DSE reduced angle booster brackets
Been looking, can't seem to find out what I'm looking for. Maybe its common knowledge but I don't know it so I will ask.
When using reduced angle booster brackets (like DSE) on a 69 camaro, will the stock pedal need to be drilled? Seems like the existing upper manual hole would be too high and the lower power hole would be too low. Would a 3rd hole have to be drilled in between to maintain proper booster rod geometry?
Old 08-27-2015, 12:05 PM
Vince@Meanstreets's Avatar
No need to drill. Just place in power (lower) hole and re adjust the rod.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 08-27-2015, 05:18 PM
[QUOTE=Vince@MSperfab;614938]No need to drill. Just place in power (lower) hole and re adjust the rod.[/QUOT
Yeah, I called DSE and thats what they said.
Thanks Vince
