Old 08-30-2015, 02:45 PM
SVPJason's Avatar
SVPJason SVPJason is offline
Default 1984 Chevrolet ElCamino SS (project)
Item Location (City/State): Pinson/AL
Price:3000
Description:Well I've decided to sell off a couple of projects. Here is an '84 ElCamino SS frame has been blasted and coated with a rust converter/sealer then topcoated with and scratch and chip resistant coating, brake fluid won't even touch this stuff!! All suspension is new, new shocks all the way around. Front has new rotors, bearings, and the rear is in the process of being converted to discs using everything from an '89 IROC. It still has the 26 spline axles, but I have a 28 spline posi carrier with 3:42 gears. Rearend and all suspension parts have been treated with the same coatings as the frame. Wheels are 16x8 IROC wheels that have been recently restored to look like brand new. Tires are the correct 245/50-16's for the wheels. Body is stripped and ready for bodywork, recently had the inside of the bed blasted, quarters and roof were hand stripped with 80grit. Bottom of the body also has been blasted , primed, and undercoated. I have 3 sets of doors, 2 tailgates, 2 sets of fenders, 1 hood, also have a '79 header panel and a SS air dam, and a set of new chrome bumpers. I have duplicates of all the glass except the windshield. Has most of the interior but is in rough shape, would suggest finding a donor Monte Carlo SS for the interior. Also comes with a good running 350 TPI from an '89 IROC, I have all accessories for the engine, all the wiring and computer for the TPI and will also throw in an extremely well written manual on doing the TPI swap. Transmission is a 700R4 from the same IROC, shifts and runs out good. have a lot of extra parts from a '79 donor I had. The Next to last pic is how I found it, the Last pic is what it looked like before I started the restoration. Asking $3000
