Closed Thread
Old 08-31-2015, 06:40 AM
Rod P's Avatar
Rod P Rod P is offline
Default Accel Performance Fuel Injectors
Item Location (City/State): Franklin TN
Price:100 bucks
Description:
Accel 151880 - Accel Performance Fuel Injectors
Accel#110-151880
Fuel Injectors Flow Rate: 80 lbs/Hr @ 43.5 psi
Type: USCAR (LS/UNV)
Impedance: 11-18 ohms
8/pkg
These run about 350 bucks...500 from Accel...look them up...there BRAND NEW...letting go for 100 bucks flat shipped to you
never used...hell I only removed this one from the box for the pictures
FEATURES & BENEFITS:
• Provides precise control of fuel delivery and atomization for increased power and improved throttle response.
• All-new units, not modified stock units or re-manufactured from used cores.
• Operates at higher fuel pressures without loss of metering control. Great for blown applications, where increased fuel pressure and precise metering are required.
• State-of-the-art manufacturing processes reduce flow deviations between injectors to improve performance.
• High-Impedance design for greater control with OEM type ECMs.
• New anti-plugging type, which will forever eliminate problems that were once associated with carbon buildup.
• Perfect for Blown/Turbo applications where increased fuel pressure and precise fuel metering is required.
• For all Port Type EFI Manifolds.
• 3 BAR (43.5 PSI) Flow Rating - 15% More Flow @ 58 PSI
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 08-31-2015, 06:50 AM
custom 68 custom 68 is offline
I will take them, PM sent.
I assume these will work on my LS motor? I forgot there are lots of other motors on here?
Dave
Old 08-31-2015, 09:34 AM
Rod P's Avatar
Dave
got that note...yep these work with an LS
Rod Prouty
Bangshift Stories
Old 08-31-2015, 12:02 PM
you should have received payment for these.
Thanks again.
David
Old 08-31-2015, 02:16 PM
Rod P's Avatar
I will send you a tracking number in the morning!
Rod Prouty
Bangshift Stories
Closed Thread
