Old 09-02-2015, 10:04 AM
samckitt's Avatar
samckitt samckitt is offline
Default Advise: Single belt & CTS-V Supercharger
i want to try & use a single belt to drive the Alt, PS, AC, WP & SC. The supercharger wasn’t in the original plan when I bought the Corvette AC/PS & bracket setup. The Holley AC bracket was kindof planned (originally was going to use the Kwik bracket, similar mounting). Then I bought the supercharger. I don’t have room to mount the AC compressor low on pass side. So I’m trying to figure out a way to use a single belt & use the accessories I have. I have the Holley spacers to push the accessories out to where the truck belt would be, which is also where the supercharger belt is located.
There is a kit out there that uses mostly GM parts, to use a 6 rib belt on all accessories except AC compressor, on one belt. I want to do something similar using the Holley AC bracket, & put the tensioner somewhere else. This is the image of it, my Alt/PS location will be a little different, but still on the driver's side.
What do you think?
Scot
86 Monte SS
LS2/T56 Magnum
Old 09-02-2015, 10:22 AM
RLJ676's Avatar
RLJ676 RLJ676 is offline
I assume the kit you're referencing is the ADM kit, that's the only one I'm aware of.
Old 09-02-2015, 01:58 PM
samckitt's Avatar
I believe it is from ADM, but I don't want a kit, rather want to piece it together myself. Does anyone know if you tensioner pictured is pne from the CTSV system, LS9 or what. Can I mount the tensioner anywhere, or is it strategically located?
Scot
86 Monte SS
LS2/T56 Magnum
