Old 09-06-2015, 09:39 PM
dcrider69 dcrider69 is offline
Default What brake fluid?
Typical setup. Brand new, dry system.
69 camaro
6 piston wilwood front
4 piston wilwood rear
Hydro boost from hydratech
Wilwood master cylinder
3/16 front lines to 3an flex
1/4 rear line to distribution block to 3/16 hard lines to 3an flex
I really prefer something that is paint and powder coat safe. Thanks.
Old 09-06-2015, 11:24 PM
ilikeike's Avatar
ilikeike ilikeike is offline
It looks like you're familure with wilwood products.
Have you looked at their line of brake fluids ? They have a silicone fluid that you might safely spill on some finishes.
Old 09-07-2015, 06:19 AM
Motul 600 is what I use in everything.
Old 09-07-2015, 06:56 PM
I'm assuming that it's probably not paint safe, since I couldn't find that info during search.
Old 09-07-2015, 09:14 PM
It'll take the paint right off! LOL
Wilwood makes some high quality, high temp brake fluids too...
Old 09-08-2015, 05:50 AM
I will continue searching, wilwood shows a dot 5 that is paint safe. From what i have read, dot 5 is not a good choice.
Old 09-08-2015, 07:21 AM
You're not going to find "paint safe" and high temp (AKA Good) brake fluid.
The paint safe stuff is silicone based - can't be mixed with other brake fluids.
I have some pretty nice "vehicles" -- I've never had an issue using brake fluid and I bleed my systems often. On the track cars - I'm constantly doing something with brakes and fluid. If you spill some - clean it up. It's not a big deal.
Old 09-08-2015, 05:59 PM
So I assume by what you're saying, I have a few seconds to get it wiped before damage actually occurs?
Old 09-08-2015, 07:30 PM
Oh you have more than a few seconds.... It's if you just leave it on it will act like paint remover and crinkles the paint. But it's not like you have to immediately wipe it off... you just never want to leave it on there. I always wipe it off, and clean my tools and anything else that's come into contact with the stuff.... and I use a cleaner like DX330 from PPG which is used to clean paint of wax and grease... or use some Simple Green or that type of thing. I think even something like Windex would work.
Old 09-09-2015, 04:10 AM
Great news. Thanks Greg!
