Old 09-29-2015, 10:38 AM
TomM's Avatar
TomM TomM is offline
Default LSA Engine PS pump fitting question.
Anybody got any ideas what can replace the factory fitting? Something o-ring with -AN threads maybe? Really don't want to buy a 50 dollar hose just to cut the end off. 2011 CTS-V engine.....
T,
Old 09-29-2015, 10:58 AM
andrewb70's Avatar
T,
Earl's make an o-ring to AN 6 fitting. Find out the size, I think they are either 18 or 16mm...I may have both in my tool box and be happy to send it to you.
Andrew
Old 09-29-2015, 12:41 PM
wadem wadem is offline
fragola makes them also and i am one of the countrys top dealers for them,get me the size you need and ill be happy to help ya out
Old 09-29-2015, 03:41 PM
dhutton dhutton is offline
Turn One used to have one. They are quite helpful when you give them a call. If you are using a rack the pressure of the CTS-V pump may be too high. They can help you there too.
Don
Old 09-29-2015, 04:05 PM
TomM's Avatar
Thanks guys appears the following numbers will work...
Russell 648060
Aeroquip FCM 2608
Earl's 919955
It is a 16MM to 1.5 o-ring to -6AN
T,
Old 09-29-2015, 05:05 PM
Vega$69's Avatar
Vega$69 Vega$69 is offline
Russell 648060
Aeroquip FCM 2608
Earl's 919955
T,
The problem I ran into with the fittings listed is the AN hose end hit the PS pulley.
I went with the Turn One Extended O-Ring fitting.
http://www.turnone-steering.com/#!on...egory=12459196
Old 09-29-2015, 06:50 PM
andrewb70's Avatar
Russell 648060
Aeroquip FCM 2608
Earl's 919955
T,
Let me see if I have one of those. I had no issues with clearance, but that was with C5 accessories.
Andrew
Old 09-29-2015, 08:09 PM
andrewb70's Avatar
Tom,
I have the earl's fitting. If it will work for you, shoot me a PM with your address and it'll be on the way.
Andrew
Old 09-30-2015, 07:01 AM
TomM's Avatar
Originally Posted by andrewb70 View Post
Tom,
Andrew
Thanks Andrew. Let me get it the shop tonight and take out the fitting that's there and verify I'm on the right track. I seem to recall the pulley clearance issue on another LS3 swap I did....I'll get back to you.
T,
Old 09-30-2015, 03:14 PM
TomM's Avatar
Attachment 55764
Yeah, you are right, just checked, the -AN fitting will hit the pulley, going to have to do the 50 dollar turn one fitting....go figure, sooooo thanks anyway Andrew....knew it wouldn't be that easy...
T,
