Old 10-05-2015, 04:43 PM
Default Can someone translate these wheel measurements to Back Space
Like the title says can someone translate these wheels to back space so I can figure spacers to use them for rollers? Or is there a conversion chart someone knows of?
The rear are 18x10 with a positive 42mm offset from center, the front are 18x8.5 with +36mm
My car is configured for 18X8 front and 19X12 rear both with 5" back space.
Old 10-05-2015, 06:34 PM
1Bad68Cat 1Bad68Cat is offline
I assume if you include the bead/lip of the wheel, the wheels are actually 11 and 9.5 wide. Therefore on the front the BS is 9.5/2+(36/25.4)=6.17. The rears are 11/2+(42/25.4)=7.15
Old 10-05-2015, 08:03 PM
kevin_l's Avatar
kevin_l kevin_l is offline
CCW has a great little calculator
http://www.ccwheel.com/technical-converter.php
Old 10-05-2015, 08:05 PM
Thank you guys this stuff make my head spin.
