Old 10-06-2015, 07:40 PM
NX Brad NX Brad is offline
Default C5 Drop spindles or drop springs on 69 Camaro
I have been fishing on sites for several weeks now and I'm total up in the air. I have a 69 Camaro i'm putting an Ls1 in. I have been doing a budget build on a and i'm at the point of picking spindles. I have decided I like the C5 setup, but I'm not sure I want to go with stock height spindles with 2" lowering springs or 2" drop spindles with stock height springs. Someone school me on the best direction to go. I would like to make this a well handling daily driver. I am planning on running 17's or 18's wheels. Thanks
1969 CAMARO SS, 1968 CAMARO, 1967 RS CAMARO And a whole bunch of other crap to keep me living in the projects.
Old 10-07-2015, 03:42 PM
Blake Foster's Avatar
Well for starters how were you planning on using a C5 spindle??? there is no control arm set up that I know of that will allow that spindle to be used. what are you going to do for steering? there is NO good reason to try to use a C5 spindle.
There ARE a NUMBER of different bolt on suspension packages available that WILL work. like this one
That will allow you to get an aggressive ride height even with the stock spindles. WE just took a car equipped with this EXACT suspension package to the Super Chevy Handling challenge. and I think everyone that drove it was impressed with both the performance and ride quality. There is no guess work no disappointment either.
Blake Foster
www.speedtechperformance.com
Old 10-07-2015, 05:57 PM
Default which spindle
The question is weather to use a 2 inch drop corvette style spindle with a stock spring or a 2 inch drop spring with a stock height spindle. I really didn't want to get into a long drawn out discussion on what parts will work with what parts, theres enough debate on those topics. I'm looking for what will give the best ride while lowering the car 2 inches, for street driving. I understand their is SEVERAL directions i can travel with an endless list of cool parts.
Old 10-08-2015, 08:51 AM
ProTouring442's Avatar
I think you're missing the point. The way you are currently asking your question sounds like you wish to only use the C5 spindle, adapting it to your stock suspension. If so, your question sound a bit like, "What is the best airplane propeller to make my sailboat go faster?" The two are simply incompatible.
So, what suspension are you running? Stock Camaro? Or are you dropping the entire C5 front suspension in?
Old 10-08-2015, 10:59 AM
redfire69's Avatar
redfire69 redfire69 is offline
If you're looking for a "C5 style" spindle, SpeedTech AFX is going to be one of the best. The tall version provides a 1 inch drop. A cheaper option is the CPP C5 style spindle CP30013. It maintains stock ride height. It is arguably more of a low budget piece made from cast steel.
Ron
69 Camaro Redfire
Old 10-08-2015, 11:06 AM
Chassisworks Chassisworks is offline
Supporting Vendor
That's a good one analogy. I'm adding that to my arsenal.
Old 10-08-2015, 11:52 AM
Rod P's Avatar
Rod P Rod P is offline
WOW!
the answer is blue....thats just as relevant as saying dropped...it will be a discussion ...because in order to give you an answer (a real answer) caster, camber, control arm pivot points, anti dive, roll center, steering units(drag link or rack), ride height, scrub radius, instant center, akerman requirement, steering radius, bumpsteer all go into deciding what to run....or you just use a complete design that someone else has done all the hard work for you ......and why a C5? because its pretty? or does it fit all those
if you ask for help and someone wants to impart knowledge to you....absorb it and learn, dont just say it dont matter
if you want the best for street driving SLAP some springs on it and move on because you dont really care how it rides or you would have listened to those trying to help
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 10-08-2015, 04:28 PM
Thanks Ron Redfire 69 that's the answers I was looking for. I think the other guys missed my point.
Old 10-09-2015, 07:09 AM
Rod P's Avatar
not really...I think you missed the point
you kinda insulted the very guy who makes the AFX/Speedtech spindle and he was trying to help you
Rod Prouty
Bangshift Stories
Old 10-09-2015, 11:18 AM
I didn't really take it that way, but I think I did answer "THE question that was asked"
gotta love how omitting 1 word can cause a cluster %$#@
Blake Foster
