Old 10-12-2015, 02:35 PM
g356gear's Avatar
g356gear g356gear is offline
Default OEM Chevy Camaro big block rad replacement??
Looking for recommendations for replacing my stock Chevy big block radiator. It has developed a crack at the upper neck connection to the tank. It needs to have Power steering provisions as well and I will still be running the stock shroud and fan. Any ideas? Thanks!
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
