Old 10-14-2015, 10:54 AM
MCB Matt's Avatar
MCB Matt MCB Matt is offline
Default American Auto Wire (AAW) Price Increase THIS FRIDAY!
Sorry for the late notice! The NEW prices for AAW Classic Update kits and other items will take effect Friday. This means only orders in to us by the end of business Friday, Oct 16th at 5 pm pacific will get the lower, old pricing!
Let us know what you need and we will get you a prompt quote.
Kits currently available for:
67-80 Camaro
67-68 Firebird
70-73 Firebird
64-72 Chevelle / El Camino
64-72 GTO
70-72 Monte Carlo
53-62 Corvette
59-68 Impala
62-72 Nova
55-57 Chevy Belair / 210 / ect
47-82 GM Truck / Blazer / Suburban
70-74 Barracuda / Challenger
62-67 Fairlane
60-65 Falcon / Comet
60-64 Galaxy / Full Size Ford
64-70 Mustang
87-89 Mustang
53-56 Ford Truck
61-66 Ford Truck
67-72 Ford Truck
73-79 Ford Truck
66-79 Bronco
76-86 Jeep CJ
Just some of the features:
- Replacement headlight switch with internal 30 amp circuit breaker included. Retention collar nut, adjustable length shaft, and custom knob are also included.
- Standard turn signal flasher, hazard flasher, and horn relay mounted on fuse panel.
- Fuse box designed to fit in original location. All required hardware supplied. New ATO fuse allows easy fuse and circuit breaker accessibility. Harness is laid out and formed to allow for nearly all aftermarket accessories such as; gauge packages, wiper systems, heat and air conditioning systems, etc.
- Original switch connector bodies! (Exclusive to American Autowire)
- Steering column connectors will plug directly into most aftermarket steering columns as well as 1969 and later GM columns which utilize stock GM turn signal switches The original column can also be wired by using the supplied mating connector and terminals.
- Along with wiring for your original dome/interior lighting, we have included separate underdash light sockets.
- Instrument Cluster wiring is designed with a “cluster harness disconnect” system for easy service and assembly. All original terminals, connectors (exclusively from American Autowire), and light sockets are also supplied for original cluster gauges. However, the best aspect of the disconnect system is that any gauge cluster package can be easily and neatly wired in. This includes AUTOMETER, CLASSIC INSTRUMENTS, COVAN CLASSICS, DAKOTA DIGITAL, STEWART WARNER, and VDO just to name a few.
- Rear body harness assembly is designed to plug into the main harness in the original connector bodies. Flexibility in harness design allows for original or custom routing. Rear body wiring includes backup light wires and mating connectors for backup light leads. License plate lead, connectors, and terminals included. Fuel tank sender wire and terminal included.
- EXCLUSIVE! You will find all the original style light socket pigtails packed into every aspect of this system making it the most complete system of its type in the industry!
- New floor dimmer switch is provided. Wire length and connection accommodate original floor mount dimmer switch.
- EXCLUSIVE! Original bulkhead connector for the engine and front light wiring is included and ready for installation. Original routing of the new harness without any body modifications!
- Engine wiring includes connectors for original points type as well as H.E.I. distributors. Power and tach connectors supplied for GM H.E.I. distributors. Alternator connectors are supplied for GM “SI” series internally regulated alternators. GM “CS” series alternator adapter is available separately.
- Front lighting includes extra long leads for special routing when custom under hood appearance is desired. All headlight, park light, and directional light connectors and terminals are provided, as well as a switched trigger wire for electric fan relay (usually recommended with AC).
- Color schematics and easy to understand installation instructions included.
Thanks to everyone who has already purchased their kit from us.
MCB
MCB Parts - Matt's Classic Bowties
5360 Gateway Plaza Dr.
Benicia, Ca. 94510
866-628-8746
TEXT ONLY: 925-989-9091 (Replied 8-4)
www.mcbparts.com
Email: [email protected]
Like us on Facebook for exclusive offers, info and chat: www.facebook.com/mcbparts
Hours: Monday to Friday 8am - 4pm Pacific
We ALWAYS enjoy talking to our customers!
We have a full time staff to answer ALL Questions, Tech Support or Order Status Tracking!
