Old 10-19-2015, 06:03 PM
Ketzer's Avatar
Ketzer Ketzer is offline
Default Any Gen 3 Hemi experience....
Anybody done a late model Hemi in a project?
Curious who's harness you used and why. Any issues you might have run into?
Jeff-
Old 10-19-2015, 07:07 PM
vipercuda vipercuda is offline
We have done a few of these projects if you want to give me a call
Mike
813-789-6179
Old 10-20-2015, 01:25 PM
Schwartz Perf Schwartz Perf is offline
Supporting Vendor
HotwireAuto is about the only company i've found that has been doing it a while.
-Dale
SchwartzPerformance
Where classic style meets modern technology.
SchwartzPerformance.com
GMachineChassis.com
LSxEngines.com
Facebook | Instagram | YouTube
Old 10-20-2015, 02:49 PM
grif54 grif54 is offline
I used Street & Performance in Arkansas for two LS harnesses. I know they do HEMI harnesses also. They were very helpful both times every step of the way. Hope it helps you out.
Old 10-20-2015, 06:02 PM
Ketzer's Avatar
Mike
813-789-6179
Thanks Mike! Waiting for my day off, otherwise I'll catch a call the second you say hello....
-Dale
Thanks Dale, that is one of the companies I'm looking at along with BPE http://www.bpeusa.com/G3Electronics.asp
The company Dale referenced is also in the same small town in Arkansas... probably a co-ink-a-dink.
Old 10-21-2015, 09:45 AM
CJD Automotive's Avatar
CJD Automotive CJD Automotive is offline
We've done quite a few. We used to make our own harness by pairing down the stocker, but as of this year, we simply use the Holley EFI computer and harness. I like the Holley setup as you can always upgrade your engine with just a few key strokes.
Old 10-21-2015, 01:44 PM
Supporting Vendor
Bouchillon (BPE) uses Hotwire Auto. They might get you a better deal than going direct though! Randy over at BPE is a great guy.
-Dale
SchwartzPerformance
GMachineChassis.com
LSxEngines.com
Old 10-21-2015, 05:43 PM
Ketzer's Avatar
-Dale
Very good info Dale. Price is definitely important but Hotwire is a lot closer to me if I got into some trouble with my first Hemi transplant.
Old 11-11-2015, 06:48 PM
Riddler's Avatar
Riddler Riddler is offline
All the Mopar shops are using Hotwire harnesses. I'm working with Affordable Fuel Injection in Michigan to build harnesses that work with HP tuners and the stock PCM.
Riddler
Old 12-10-2015, 05:52 PM
andrewb70's Avatar
Holley now offers plug-n-play harness and ECU kits for GenIII hemies.
Andrew
