Old 10-24-2015, 09:46 PM
70PTRS 70PTRS is offline
Default Rear gear ratio
I'm going to be running a 25.9 tire (Rival 335/30/18) and a T56 magnum with a 2.97 1st gear and .5 6th behind a 450 rwhp LS1. What's the optimum rear gear ratio for my set up?
1970 RS Camaro '02 LS1, T56 Magnum in process
Old 10-26-2015, 10:17 AM
What type of driving? All around, autox, competitive autox, road coarse, etc?
Old 10-26-2015, 11:01 AM
Mostly all around with an occasional autox and a few trips to the drag strip every year.
Old 10-26-2015, 11:34 AM
Sieg's Avatar
Sieg Sieg is offline
It's a loaded question!
Here's the best tool I found to help me make the decision: http://www.tremec.com/calculadora.php
Do you already have the transmission?
Old 10-26-2015, 09:35 PM
Yes I already have the trans.
I'm thinking a 3.70 or 4.11? With a 3.70 at 1800rpms I'm cruising at around 75 in 6th;
With a 4:11 at 2000 rpms I'm cruising 75.
3:70 at 6500 in 4th gear Im going 135, 4:11 is 121 which is around what the car should trap in the 1320.
Old 10-27-2015, 06:26 AM
I was going to suggest a 3.73 or 3.90 ratio for an all around car. I think any gear in the 3.70 to 4.10 range will work well for you honestly.
Old 10-27-2015, 07:15 AM
Moose Moose is offline
I have the 4.11 in mine with your exact same setup. Love them. Pulls hard out of corners on autocross. It will spin the tires at drag strip, you're going to find that right launch point.
The 3.73 are just 1 step up over stock for original 4th gen f-bodies.
One last thing. on power tour in 2014, I was getting 24-26 mpg when I kept my foot out it..
Mike
Old 10-27-2015, 11:47 AM
Awesome info; I think a 4:11 is what I'll be ordering. Thanks guys!
Old 10-29-2015, 07:22 AM
Tony V Tony V is offline
Same set as yours and i went with 3.70
but put together a quick table to evaluate options
I can send you the excel file if you want to play around with the options....
Old 10-29-2015, 10:54 AM
I think any one of those 3 will work. I may split the difference and go with the 3:90's
Which gears are better quality and quieter, Motive or US Gear?
