Old 10-25-2015, 03:36 PM
paulk68 paulk68 is offline
Default Order of things
Alright so I have a question on what I should do next. My 68 camaro shell is sitting in primer on a old subframe and stock suspension. i modified a spare front subframe for my front ridetech suspension and then had the fame painted. I need to focus on ordering a rear end and starting on the rear bolt in 4 link. i am probably going to farm that out cuz i am not a welder and will need all the rear end brackets welded on. Should i send it out on it's old suspension or should i put the new painted subframe on with all the ridetech stuff and then send it out for the rear end stuff.
Paul
Old 10-25-2015, 07:24 PM
Vega$69's Avatar
Vega$69 Vega$69 is offline
Old front
Old 10-25-2015, 10:37 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Paul
The simple truth is that no one values or respects your stuff like you do. There are a lot of good shops out there and they will try, but at the end of the day the smart thing to do is to send it out with the old stuff. Don't send anything you don't have to. Things get misplaced and lost all the time. It just snow balls and becomes a huge problem. Save your self the headache and send it with the old stuff and minimal parts.
Curtis
Old 10-26-2015, 10:01 AM
Thanks guys, makes perfect sense!!
